Help 92 Lt-1 code 34 wont go away
Old Sep 10, 2007 | 05:24 PM
BGH's Avatar
BGH
Default Help 92 Lt-1 code 34 wont go away
I cant get this code to go away. I have done
a known good map sensor, new plugs,wires,fuel filter,
air filter,pcv valve,IAC valve,tps and even map sensor
connector. It loads up and backfires at part throttle
but runs great at full throttle. Have disconnected battery for
days but problem is still there. Please Help.
Old Sep 10, 2007 | 09:23 PM
BGH's Avatar
BGH
Any Ideas? It runs great at full
throttle.?????????
Old Sep 11, 2007 | 04:27 AM
toptechx6's Avatar
toptechx6
Have you run the electrical tests in the service manual to check the wiring between the ECM and the MAP sensor?
Old Oct 17, 2007 | 09:52 PM
BGH's Avatar
BGH
Found the problem. After running all the test
I found everything in spec, so I decided to
call Gordon Killebrew[ nice guy]
The problem was the new K@N filter
I bought had too much oil on it from
the factory. Never heard of this but Gordon
has seen it. Anyways I hope this helps
someone else sometime.
To Help 92 Lt-1 code 34 wont go away
