need engine gaskets for my 84 cfi ( where 2 buy? )
Old Sep 10, 2007 | 08:53 PM
brian84's Avatar
brian84
Default need engine gaskets for my 84 cfi ( where 2 buy? )
hey guys, I finaly got my spare crossfire intake manafold for porting, and am about to start porting this thing. ( man alot has to come off it ) - but I figured I should start ordering parts now so I have them when its time to swap intake manafolds. - but I cant seem to find any that are for my car. - where would I look to get them?
I know I need - the diamond shaped gasket for the upper/lower intake manafold, and also the "kit" for the intake to heads - I am going to need a pair or 2 of throttle boddy to intake lid gaskets, and I guess its also a good idea to have some spare tb rebuild gaskets also avalable just incase of an air leak or something.
is there a place to buy all the above mentioned pieces from in a all in one kit? I have not found it yet.
thanks for the help.
Old Sep 10, 2007 | 09:25 PM
CFI-EFI's Avatar
CFI-EFI
I just bought mine at a local parts store. Fel Pro makes an intake manifold set that includes everything you named plus a tube of black silicone for the end rails (china walls) and a distributor gasket. If you've removed them, you will need the water outlet and EGR gaskets separately. The TB rebuild kits, are a separate item.
RACE ON!!!
