Power expectation on complete build?
I'm interested in increasing the acceleration of a stock 85 vette, assuming a complete engine rebuild. I would prefer it have a minimum 91 octane pump gas requirement, retain a stock appearance with the TPI, retain a normally aspirated configuration, and keep it street legal. The car would be a toy, only used in and around town. I also however want to retain A/C and cruise. Acceleration is the goal, top speed not so much. I have considered .373 gearing and the appropriate exhaust.
Assuming the complete engine buildup, what would be a reasonable expectation on horsepower and torque? My budget for this change project is around 10K.
What say you?
What say you?
You could easily get a proven 383 combo with good heads, and properly tuned for less than $10K. You could also build a fast 350 (just doing your top end) and still be under $10K.
In either case, you need to set some expectations as to what you would consider fast.
Ron
Just go with a 355 or 383, 170-180cc heads (because going bigger with TPI would be pretty much a waste), a rather mild cam like the Accel 211, or maybe a bit bigger with the bigger engine.
Still it will need upgraded TPI parts to feed it, larger base, runners, ported plenum.
I could find better ways to spend 10k.
Do you want a minimum of 91 octane or a maximum of 91 octane? When you say minimum that means that you want to run either 91-3 octane or racing fuel, did I read this correctly? Wouldn't you want something that would need 91 as the maximum?
What say you?
Heads
Intake
cam
Valve Train
forced air
Exhaust
Torque Converter
Shift kit
and have a pretty fast car. If you do the work yourself.
