Electric Waterpump Longevity
Old Sep 12, 2007 | 05:14 AM
wilsonbh's Avatar
wilsonbh
Default Electric Waterpump Longevity
Anyone have an electric waterpump on their engine that has lasted a long time? The local Corvette mechanic is telling me that it's insanity to install one of these unless you race your car.
Thoughts? Comments?
Billy
Old Sep 12, 2007 | 06:08 AM
ericcer's Avatar
ericcer
To me the insanity part of it is not having a warning circuit installed with one. Mine saved me from overheating just last week when one of my relays that drives the pump went bad. I was at 210 degrees when my alarm went off. It took me less than a minute to pull over and shut the car down. The coolant temps got up to 245 in that period of time.
I would not run a electric WP without a warning circuit. I want to point out that there are two coolant sensors on my 96 (maybe the same for all C4s). One in the WP housing and one in the head. On the dash, the digital display shows you the WP housing sensor and the analog gauge shows you the one in the head. When an electric WP fails the analog gauge shoots to the danger zone while the other one changes very slowly so you may not even notice the failure if looking at the digital gauge before it is too late.
When a electric WP fails there is NO coolant circulating at all whereas a mechanical one there is. Usually the mechanical ones warn you by leaking.
Old Sep 12, 2007 | 06:42 AM
Road Agent's Avatar
Road Agent
Thoughts? Comments?
Billy
Old Sep 12, 2007 | 08:35 AM
BlackC6LS3's Avatar
BlackC6LS3
Could you give us some details on this warning circuit?
Old Sep 12, 2007 | 09:17 AM
ericcer's Avatar
ericcer
They last about that same from what I have read. I remember someone claiming the electric one would outlast the mechanical.
The warning circuit I use is from this site below.
http://mywebpages.comcast.net/khartn...02/circuit.htm
Old Sep 12, 2007 | 09:50 AM
Strick's Avatar
Strick
I've had my Mez coolant pump for 25K now and it still works fine. Our electric fans work fine and last a long time. I watch my gauges a lot and normally ride with the "gauges" and coolant temp displayed. I also ride with a spare jumper just in case the relay fails. That will get me home. I thought about a spare circuit in parallel that I could switch to, but haven't done so. I also thought a light showing the pump is on would be nice to have. I like the idea of eliminating the oil leak problem from the mechanical water pump seal. For over kill in preventive maintenance, I'll probably change it out at 50K. Then I'll have a spare pump.
Old Sep 12, 2007 | 12:03 PM
STL94LT1's Avatar
STL94LT1
Old Sep 12, 2007 | 10:40 PM
Hotred94's Avatar
Hotred94
Thoughts? Comments?
Billy
That's what they said about electric radiator fans when they first came out, now they're the standard. My mez has gone one year so far with no problems. By the way, nice color on the car.
Old Sep 12, 2007 | 10:45 PM
STL94LT1's Avatar
STL94LT1
I've been running my HD Meziere for over 4 1/2 years. But, with my car that has only been about 10k miles.
Old Sep 12, 2007 | 10:48 PM
RRT vette's Avatar
RRT vette
About the same here. It was installed almost 3 years ago, but only about 9K miles. So far, so good.
Old Sep 13, 2007 | 06:42 AM
93 ragtop's Avatar
93 ragtop
Thoughts? Comments?
Billy
With that mindset, would he also suggest that you should remove the electric fuel pump and go back to a mechanical one?
Old Sep 13, 2007 | 09:21 AM
Strick's Avatar
Strick
Originally Posted by STL94LT1
Nice diagram, but what does this stuff look like? What does it look like installed? Where do you get this stuff?
To Electric Waterpump Longevity
