'93 Speedometer backlight dimmed.
Old Nov 9, 2001 | 09:11 PM
Wadoka's Avatar
Wadoka
St. Jude Donor '03-'04
Cruise-In 1-2-3-4-5 Veteran
Default '93 Speedometer backlight dimmed.
The speedometer panel on my '93 coupe suddenly seems about half as bright as it used to be.
Also, I've completely lost the backlight on my radio clock/frequency display.
Is the LCD lit separately by replaceable bulbs? Has anyone has this problem and repaired it?
~Matt
Old Nov 9, 2001 | 09:59 PM
shepsvettes's Avatar
shepsvettes
Default Re: '93 Speedometer backlight dimmed. (Matt Black)
I have the same problem on my 93 at times but the radio display stays the same just the spenometer display dimming. :cry :cry
Old Nov 10, 2001 | 01:36 AM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
Shine a bright light at the ambient light sensor opening (on the drivers information center) and see if anything changes. If nothing changes you'll need to follow the ambient light sensor functional check list (long). Page 8A-114-9 in the 92 manual, should be the same on the 93. :crazy:
Old Nov 10, 2001 | 01:55 AM
Wadoka's Avatar
Wadoka
Default Re: '93 Speedometer backlight dimmed. (Ramrod92)
Running to find a flashlight now...hmm...it should be dimmer in darkness, brighter in daylight, what a concept...:D
Wait a minute, tho...it's at *night* that it seems to be dimmer than it should be. Have to crank the slider all the way up, when halfway used to be too bright.
Thanks. I'll be beck.
[Modified by Matt Black, 11:57 PM 11/9/2001]
Old Nov 10, 2001 | 03:41 PM
Wadoka's Avatar
Wadoka
Okay, no help. It responds as it should lights on / lights off / dark / light.
My service manual does show two lightbulbs for backlight. I wager I've lost one of the buggers.
~Matt
To '93 Speedometer backlight dimmed.
