Break Down! It finally happened...
Old Sep 12, 2007 | 12:41 PM
PakHeat's Avatar
PakHeat
Default Break Down! It finally happened...
I start the vette and drive 3 miles down the highway. I come to the off-ramp and while sitting at the red light, the idle starts to get a little rough. I turn the A/C off and it gets worse. The engine then quits.
I drift to the side of the road and try cranking her over. Cranks really nice, but won't turn over. Fuel? I wait for awhile and the engine starts! It runs for about 2 minutes and when I put it in gear, it stops and won't start again!!
I have the car towed (I have a picture for later...) to a garage that I find out is CLOSED for vacation the next week.... damn. I wait the night, go to the car and again it starts and runs for about 3 or 4 minutes. I don't put 'er in gear, but it then stops just like before.
So my car is sitting in this garage lot and I need some help! Can anyone give me some?
Thanks!
Old Sep 12, 2007 | 01:26 PM
bdw18_123's Avatar
bdw18_123
From: Prather, California -1990 ZR-1 White/Flame Red- -SOLD!!-
Sounds like a fuel problem. Especially since it starts up again after you let it sit. You should hook up a fuel pressure guage to the fuel rail and watch the fuel pressure while its running to see if it drops just before the engine quits. Maybe your fuel pump is going bad, or you might have a clogged fuel filter. Just my 2 cents.
When you said the idle was getting rough, did it sound like it was running out of gas?
Old Sep 12, 2007 | 01:28 PM
89vettefromhell's Avatar
89vettefromhell
sounds like a Fuel Pump issue... it sounds as if its some sort of Fuel issue for sure... check your fuel relays, check your pump, check to see if any codes have been thrown. check injector pulse...
in my opinion i would go through all the fuel stuff first... this is exactly what happened with my 89 the first couple months i had it.. i replaced the relay and i replaced the pump and BOOM running again...
Old Sep 12, 2007 | 01:32 PM
PakHeat's Avatar
PakHeat
You guys are probably right. It did seem to 'run out of gas'. I suppose I should change that first. I am just freaking out over it being the first tow job!
Old Sep 12, 2007 | 01:41 PM
shortcut96's Avatar
shortcut96
I know this may sound stupid but does the car have sufficent amont of gas in it.Our c4's a notorious for gauges being wrong.If it does then it sounds like a fuel pump or relay issue..Good Luck keep us posted alot of smart people around here to help you out.... Also post this in the regional forums you might find someone nearby that will lend a hand..
Old Sep 12, 2007 | 02:23 PM
Da Mail Man's Avatar
Da Mail Man
.....had a similar problem and mine turned out to be the ignition module....
Old Sep 12, 2007 | 06:08 PM
PakHeat's Avatar
PakHeat
Ah, yes, the ignition module. I read a thread about that. I also thought about the guage not reading correctly. I had just filled up the day before and it still had a healthy amount of gas.
I'm still leaning toward buying the relay, trying that and then the fuel pump if that doesn't do it. If that's not it, I'm going to let the mechanic take it from there. Oh, crap..
Anyway, I'll keep you posted on the outcome!
Old Sep 12, 2007 | 08:17 PM
PakHeat's Avatar
PakHeat
Sometimes she sucks.
http://i232.photobucket.com/albums/e...t/P9080001.jpg
Old Sep 12, 2007 | 08:29 PM
williammackean's Avatar
williammackean
St. Jude Donor '07
Don't feel bad. I have a friend whose car is named Cleopatra. It's black & sexy. Every man wants his hands on and in it. You hear it coming miles away. It turns every head when it goes by. It is dripping with power and allure. AND it often returns home on a covered platform on another man's back.
To the point:
Do you hear the fuel pump kick in when you turn the key forward to the 'on' position? Do you hear a click from the relays on the firewall?
Filters and relays are cheap and easy to do. Start there.
If you hear the relay click, but not the pump, check the fuse. If the fuse is OK, you might have a bad pump. Pull it from the top. Don't drop the tank like the FSM says.
Pull the vac line off the pressure regulator under the plenum. Is fuel in the line? That would mean a bad diaphram. ~$80. Get the AFR while you're at it and set it to ~45psi primed.
Keep us posted!
Old Sep 12, 2007 | 08:43 PM
hippy's Avatar
hippy
I doubt it's fuel but put a gauge on the schrader. I'd bet that the fuel pump isn't the problem. Did you get a crap load of gas?
Old Sep 12, 2007 | 09:07 PM
JackDidley's Avatar
JackDidley
Check fuel Pressure. If its low, at least the pump may be the easiest repair you ever do on the car. No sweat involved. Less than $100 too.
Old Sep 12, 2007 | 10:23 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
Old Sep 12, 2007 | 10:36 PM
_twisted_'s Avatar
_twisted_
the sock on my pump went and caused similar problems
Old Sep 13, 2007 | 03:45 PM
PakHeat's Avatar
PakHeat
I did hear the pump when I turned the key. I don't ever remember hearing the relay. I don't think I've ever heard the relay.....
Hmmm.
Going to order the relay.
I also have a guage on the fuel rail. The wife watched it come up to full pressure when the car would start, but we didn't watch it when it quit. Damn. I'll go take a look tonight!
I miss my car, man.
Old Sep 13, 2007 | 09:04 PM
williammackean
St. Jude Donor '07
Leave the guage attached and tape it to the windshield. Prime it. Note the pressure. Start it. Note the pressure. Let it idle for a while (or until it quits). Note the pressure. If it doesn't die, rev it at ~ 1500 and note the pressure as it dies.
If the pressure stays above 30-35 when it dies, it's not likely fuel related.
Could just be something goofy when it hits closed loop.
BTW: If your pump engages, it might not be the relays. Not a bad idea to replace them and the filter, since they're both cheap. It eliminates a possibility.
Old Sep 14, 2007 | 11:43 AM
XXXBLK's Avatar
XXXBLK
This sounds familar; a quick test for you, check the ohms readings on all your injectors. They should be around .016-.017 ohms. I am guessiing you have around 3 bad injectors. Just my two cents...
Old Sep 20, 2007 | 10:24 PM
PakHeat's Avatar
PakHeat
DaMailMan WINS! It was the ignition module!
Total cost with tow: 200.00.
Thanks to everybody for the input!
Old Sep 20, 2007 | 10:51 PM
Can86Z51's Avatar
Can86Z51
Sounds very similar to what happened to my 86 a couple of years ago! Turned out to be a bum fuel pump RELAY. Would start/run for a short time, then die.
Old Sep 21, 2007 | 09:40 AM
PakHeat's Avatar
PakHeat
I was thinking the same thing about the fuel pump relay. I guess because it was so cheap to replace. You know, start with the least expensive first, then move on from there kinda thing.
I know some guys here carry spare parts in the car.
Maybe it's time for a good thread on what extra replacement parts people carry with them in case of breakdowns.
To Break Down! It finally happened...
