383 stroker guys
Old Sep 12, 2007 | 04:55 PM
BTTB's Avatar
BTTB
Default 383 stroker guys
what size injectors are you using
Old Sep 12, 2007 | 06:08 PM
Happydad's Avatar
Happydad
750 Holley D/P
Old Sep 12, 2007 | 06:16 PM
Matt383's Avatar
Matt383
From: 2003 Points Champ Great Lakes Corvette Challenge; 2006/2007 Winner MSD True Street
68 psi
Old Sep 12, 2007 | 06:46 PM
JOHN89's Avatar
JOHN89
24# set at 52 psi
Old Sep 12, 2007 | 06:57 PM
chucks88's Avatar
chucks88
FMS 24# ers
Old Sep 12, 2007 | 07:36 PM
JAKE's Avatar
JAKE
If you're just taking a survey, that's one thing, but if you're looking for a recommendation, that's another. It'll depend on several variables: Head flow, camshaft, CR, etc.
I asked Bryan at PCMFORLESS which ones I should run based on the parts I selected for the 388 I was building. He recommended 30#; that's what I'm running.
So put me down for 30#.
Jake
Old Sep 12, 2007 | 07:37 PM
black_89_vette's Avatar
black_89_vette
Old Sep 12, 2007 | 08:33 PM
jeffyc's Avatar
jeffyc
fms #30
Old Sep 12, 2007 | 09:49 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
30s
Old Sep 12, 2007 | 11:19 PM
xrcrx's Avatar
xrcrx
64# & 66# w/vafpr at 23psig. So far....
Old Sep 12, 2007 | 11:34 PM
Carpenter's Avatar
Carpenter
FMS 24# @45 psi.
(52mm bbk; mild port heads; slp shorties; 3" exh w/bullitts)
Running fast but rich right now (plus other issues) Have yet to dyno-tune/re-flash. (perhaps next month)
Old Sep 13, 2007 | 12:12 AM
85vet's Avatar
85vet
Cruise-In V Veteran
Originally Posted by chucks88
FMS 24# ers
Check with your tuner.
Old Sep 13, 2007 | 12:44 AM
dock351's Avatar
dock351
St. Jude Donor '06
24 lb accels. run at 42 psi. superram and ported etc 113 heads.
Old Sep 13, 2007 | 06:11 AM
93 ragtop's Avatar
93 ragtop
50's with plans of going to 96's But I purchased a turbo car!!
Actually, injector size is based on HP rather then CID
The car in my signature is running stock injectors, but they are maxed out and its going lean on top end.
Old Sep 13, 2007 | 09:29 AM
FD2BLK's Avatar
FD2BLK
36# FMS but have ran 28's and 42's and all will tune to the proper AFR. The reason for so many injectors was with the 28's the DC were near 90% and I thought I had a problem with the 36's and bought the 42's but found out the problem was not my injectors so I changed them back to the 36's
Old Nov 8, 2007 | 10:25 PM
gtslow's Avatar
gtslow
30# at 45psi
Old Nov 8, 2007 | 11:34 PM
Zix's Avatar
Zix
SVO 42# at 48 psi
Old Nov 10, 2007 | 09:01 AM
cruiserto's Avatar
cruiserto
Default injector size
google, "fuel injector size calculations" there are a few really good calculators
Old Nov 10, 2007 | 11:41 AM
Corvette0096's Avatar
Corvette0096
SVO#24 And my fuel trims are dead on.. Tested by TJWONG and as you might know is a tunner as well
To 383 stroker guys
