Looking for vacuum leaks, I took off the air cleaner and found it not seated correctly and grass was in the screen of the mass air sensor ! How do you clean it without hurting it? I was going to just brush it off with a soft paint brush, but I'm wondering about the electronic sensor being coated with oily dirt. I've heard not to spray throttle body cleaner on it. Is that true? Also, is there a special tool to take off the small metal bands on those rubber flex pipes attached to it? I took them off once before and spent the rest of the day trying to get them back on.
You are looking for this below. It is from a company called CRC. Like the others said most Auto parts chains sell it. I've bought it from Pep Boys and Auto Zone. You can also get it online. Not sure if there are any issues with shipping though.
I take the mass airflow sensor apart on my cars often. The elements inside will look like little chia pets if you do not keep the electric wire clean.
The performance gain can be noticed if they are dirty. The screen on the LT1 is seperate from the actual maf wires. The four torqx screws will get you to the actual elements.
I've never seen a performance gain by spraying the sensing wire with anything, at least not on a scan. These things seem to read air flow correctly or they don't. The last one I bought went about 4 years before my BLM's suddenly went lean - 132 to 136. After ruling out other causes, I swapped in my OEM, 18 year old, screenless spare, and got a perfect mix - 128. Hook up a scanner before and after and see what it says. If the burnoff is working, I don't know why you'd see any difference and if you don't, check your air filter - particularly if it's a well oiled K & N - in fact I'd throw that out along with getting a new MAF.
Cleaned up the Mass Air sensor and went on to clean up the throttle body. This is the first time I've had it off this car.(Had it a year) I decided to take off the plate that says "Grand Sport", because there was something nasty looking stuck under there. Well, I found there was a wrinkled up old rubber gasket in there, and there is a passageway under there too. I thought it was just a "look pretty" plate!
I went to PepBoys again and they didn't have one, so NAPA was my next stop. Got the "deer in the headlights" look there too, so I'm doing the good old Cheerios box gasket thing. Us Ford guys know that the very best gaskets are made from a Cheerios box !
Now why didn't I think of that. I just left mine off about a year or two ago.
A few years back I installed a K&N filter. Installed it right out of the box with factory applied oil. A few weeks later I noticed my BLM and Intergrtor values had radically changed - I was reading using Diacom.
After checking several things, I removed the MAF and sprayed the wires. Everything went back to normal after that.
Oil from the filter had accumulated on the wires causing the ECM to receive incorrect readings. I now periodically spray the wires on both my 86 and 96.
