'90 with A/C issues
Old Sep 13, 2007 | 05:22 PM
jghmczo6's Avatar
jghmczo6
Default '90 with A/C issues
Replaced the check valve as recommended by forum members, A/C worked fine. Yesterday when I started the car A/C would blow slightly, typically once the air began to circulate the blower would kick it up a notch and blow even harder. Today blower fan speed set at 10, again only minimal air from the vents, inside temp setting 60-65* outside 104-107* I reset the system by pulling fuses #1 and #17, to no avail.
What is the next step is this vacuum, blower motor, or fuse?
Thanks for the help................................:coo l:
Old Sep 13, 2007 | 06:36 PM
SunCr's Avatar
SunCr
Default is to delay full blower a couple of seconds which allows any moisture ladened air to be discharged through the heater vents. You need to troubleshoot the Blower Module, Programmer and Controls. I'd start by checking the integrity of the Blower harness at the Connector. That can heat up (drop volts) if the terminals are loose and melt the wires. I'd also jumper the Blower directly to the Battery just to make sure it works.
Assuming the Blower Motor and wiring is good, move to the Module, mounted on the left side of the Evaporator case. It gets low voltage signals from the Programmer and amplifies them to control Blower Speed. That input is usually Brown or Tan (and with age, it may appear to be Black which is also the color of the ground for this device). At 10, that wire should have at least 6 volts on it. If it does, the output - purple - should be at 12 volts. If it has the input and the output is wrong, you need a new Module. You might also check ground (spliced to the blower and terminating on the frame below it) and power - red (fused and usually labled Prgm in the box). If the input isn't there, then the problem is in the Controls or the Programmer. Controls communicate over serial data lines with the Programmer. Little you can do to troubleshoot either without a bi-directional scanner, but assuming the Controls work; ie, when you push a button the Display changes and the compressor engages the more probable suspect is the Programmer. Before you replace anything though, disconnect and reconnect the battery. That will insure that it isn't just a memory glitch.
Old Sep 13, 2007 | 07:33 PM
jghmczo6's Avatar
jghmczo6
Thanks SunCr you are always a great help, I will try the battery first thing in the morninng if that is unsuccessful will attempt the others Saturday A.M.
Thanks again for your help............................
To '90 with A/C issues
