Jakester I think your pressure is a little high for a stock motor. My L 98 has alot of bolt on's and my fuel pressure is at 40 and maybe could go even a little lower like 38. I would lower it. Hook your pressure gage to the fuel rail remove the vacum line start it up then lower it some and don't forget to put the vacum hose back on and take her for a ride. If it stumbles you might have to lower it some more. Pipe
Stock injectors seem to "lock up" when the fuel pressure gets much above 48 psi. Because of the "locking up" the car would seem to go lean and misfire.
