'95 LT1 has a problem
Old Nov 10, 2001 | 03:04 PM
SLOWBUSA's Avatar
SLOWBUSA
Default Rough running '95
I have a '95 LT1 that is running terrible.:mad The problem is that it is running really rough. The exhaust makes deceleration type of noises when cruising on the interstate and there is a definite lack of power.:sad: The car also idles rough at about 600rpm. It seems to constantly stumble and shake at idle. Could this be a bad injector? I checked the fuel pressure and it is steady at about 46psi. Has anyone had a similar problem? Where should I take the car for diagnostic work? I appreciate any help. Thanks.
[Modified by SLOWBUSA, 7:44 PM 11/12/2001]
Old Nov 10, 2001 | 05:01 PM
929rr
Default Re: '95 LT1 has a problem (SLOWBUSA)
Probably your Optispark distrubutor..... When they get moisture in them they are pretty much toast. And a pain to replace. I have had this problem on a few LT1's that I have owned in the past.
Also, with your name, SLOWBUSA, do you own a Hayabusa?
Old Nov 10, 2001 | 08:10 PM
SLOWBUSA's Avatar
SLOWBUSA
Default Re: '95 LT1 has a problem (929rr)
Yes, I own a 2000 Blue&Silver 'Busa. I hope it is not the optispark.:eek: I am checking the fuel system first. Will check the ignition next. Thanks for your reply. :chevy
[Modified by SLOWBUSA, 6:11 PM 11/10/2001]
Old Nov 10, 2001 | 08:15 PM
LPDesRoche's Avatar
LPDesRoche
Unfortunatley you can almost bank on that problem being the OPtispark. I had the same problem before on previous cars. Shop around for the OPTI you can get them much cheaper than you may think.
Old Nov 10, 2001 | 10:04 PM
SLOWBUSA's Avatar
SLOWBUSA
How do you tell if the problem is the Optispark?
Old Nov 12, 2001 | 09:45 PM
SLOWBUSA's Avatar
SLOWBUSA
Default Re: Rough running '95 (SLOWBUSA)
Where should I take my car to check the codes?
Old Nov 13, 2001 | 12:11 AM
Raysur's Avatar
Raysur
Rough idle = bad IAC.
It's around $27 and its very easy to replace. But if you lack power you might have a bad injector. It sounds like your car is not running on all eight cylinders.
You have a bad opti spark if your car misses at high rpm (5K or so).
Old Nov 13, 2001 | 12:19 AM
AS84's Avatar
AS84
I don't think you could make a 'busa slow could ya :D
To '95 LT1 has a problem
