94 blowing start switch
Old Sep 16, 2007 | 01:44 PM
Sailfish40's Avatar
Sailfish40
Default 94 blowing start switch
i keep blowong the start fuse. I replace it and a few starts later it pops...
Not sure what is the problem. I am noticing the temperature shoots up to +220 degrees. could this be the cause??
Old Sep 17, 2007 | 08:13 PM
bsmutz's Avatar
bsmutz
Not likely. More likely that the starter is drawing too much current. Besides the work getting it out, it should be less than $50 to get it rebuilt. Have the solenoid checked at the same time.
Old Sep 20, 2007 | 12:24 PM
ineVETTEable's Avatar
ineVETTEable
Seems to me the start relay just enables the starter solinoid. I would think the problem is between the ign.switch block and the relay no?
Old Sep 20, 2007 | 04:15 PM
Sailfish40's Avatar
Sailfish40
sorry for the bad info but actually it was the fuse that blew and not the switch... I started a new thread with the correct information cause i did not know how to fix the current thread..
Old Sep 20, 2007 | 05:45 PM
ineVETTEable
none the less the fuse is between the relay and ign.switch.
To 94 blowing start switch
