94 - Keep blowing start fuse.. 5 amp
Old Sep 16, 2007 | 01:51 PM
Sailfish40's Avatar
Sailfish40
Default 94 - Keep blowing start fuse.. 5 amp
i keep blowong the start fuse. I replace it and a few starts later it pops...
Not sure what is the problem. I am noticing the temperature shoots up to +220 degrees. could this be the cause??
Old Sep 16, 2007 | 03:21 PM
Sailfish40's Avatar
Sailfish40
any takers?
anyone know anything on this issue?
Old Sep 16, 2007 | 08:15 PM
yoitsmatt's Avatar
yoitsmatt
the 5 amp crank fuse runs to the clutch switch (purple wire) or p/n switch on an auto car and then the control side of the start enable relay(yellow wire) and then to the to the ccm(yellow and black wire) (central control module) that grounds that circut and turns on the start enable relay. I'd take a good look at the wires them probably try a relay, that would be cheapest, unless your really good with a mult-meter and can trace the short, hope this helps.
Old Sep 17, 2007 | 01:13 PM
Sailfish40's Avatar
Sailfish40
yes, I was thinking of changing the relay since it is only a few $$$. However, I cant find the darn thing anywhere... do you know where it is?
Old Sep 18, 2007 | 08:24 AM
Sailfish40's Avatar
Sailfish40
can anyone point out where the start enable relay is located on a 94?
Old Sep 18, 2007 | 01:11 PM
fuzzydawg's Avatar
fuzzydawg
I've got the FSM for my 94 at home... will check tonight.
Old Sep 18, 2007 | 01:27 PM
Sailfish40's Avatar
Sailfish40
man that would be of great help to me... thanks...
Old Sep 18, 2007 | 02:11 PM
Sailfish40's Avatar
Sailfish40
by the way, which FSM do you have? I would like to buy one and not sure what to get...
To 94 - Keep blowing start fuse.. 5 amp
