Headlight motors work backwards
Old Nov 10, 2001 | 07:17 PM
XtremeMachines's Avatar
XtremeMachines
5th Gear
Default Headlight motors work backwards
I just installed a new gear and bushing set and now when I turn the headlights on one goes up and one goes down. What do I do? :boxing
Old Nov 10, 2001 | 07:59 PM
ZBRA's Avatar
ZBRA
Default Re: Headlight motors work backwards (XtremeMachines)
Try this: Turn them on. Go to the headlight that is down and twist the emergency **** at the top of the motor until the headlight is up like it should be.
Turn them off, they should both go down. See if they are working right now.
Old Nov 10, 2001 | 09:33 PM
XtremeMachines
5th Gear
Default Re: Headlight motors work backwards (ZBRA)
I tried but they still don't work.
Old Nov 10, 2001 | 11:06 PM
ZBRA's Avatar
ZBRA
then you probably reconnected the linkage wrong on that side. You may have to pull the little piece off that bolts to the output shaft on the motor and flip it over.
It's hard to say without looking at it.
Old Nov 11, 2001 | 05:29 PM
XtremeMachines
5th Gear
I checked and the linkage looks the same as the side that works.
To Headlight motors work backwards
