building383??what pistons guys??
Old Nov 10, 2001 | 08:02 PM
my96lt4vette's Avatar
my96lt4vette
Default building383??what pistons guys??
i am building a 383 with a 3.750 crank and 5.7 rods.does anyone have agoo suggestion for a set of pistons that are strong and reasonable ? everything else is 4340 forged and i may run a shot of 100hp nitrous on rare occasions
thanx for any help
doug s.
:chevy :confused:
Old Nov 10, 2001 | 08:09 PM
WG87's Avatar
WG87
Default Re: building383??what pistons guys?? (my96lt4vette)
SRP or Probe
:cheers:
AS84's Avatar
AS84
I have srp's in my race motor. Its a 13:1 with 150 shot of nitrous. These pistons have an 11cc dome and they sit below a 62 cc combustion chamber. I have had good luck with srp.
Old Nov 10, 2001 | 08:27 PM
Chris@SD's Avatar
Chris@SD
SPR is an excelent piston. We use these up to about the 200-250 HP nitrous level. Then we move up to JE's.
Let me know if I can help.
Thanks,
Old Nov 10, 2001 | 11:25 PM
No Go's Avatar
No Go
I was looking at doing this sometime in the future and my latest Jeg's catalog came in the mail. They now carry SRP's-I was benchracing PN #867-138089. They are 11.8 to 1 with a 58cc chamber flat top. Only ~$450. I'm sure 2FST4U could do better though...:)
They seem to be the piston of choice for many-fairly tight piston to wall clearances and overall strength. I've only used TRW's so far though...
Old Nov 10, 2001 | 11:55 PM
WG87's Avatar
WG87
Default Re: building383??what pistons guys?? (No Go)
No Go,
if nothing else you'll like for the piston to wall
clearance, there are better for not a whole lot more
dough but like 2fst4u said small shot nos or no
extended high rpm(like long round track) there
a good buy.
Wayne
Old Nov 11, 2001 | 09:39 PM
my96lt4vette
Default Re: building383??what pistons guys?? (2FST4U)
hey chris,was wondering what srp to go with considering the compression ratio for an LT4 is alraedy 10.8to1 ?? i saw i new jegs catalog with maybe the right piston for me but cannot remember the pn# ?? also looking for a set of gears and may consider anything between 4.09-4.30?? i hear that 4.27-4.30's put you at the end of the 1/4 mile right at the top of the rev limit for an
LT4 motor ?? was thinking of going with the 219 lingenfelter cam also !!!
:chevy :confused:
Old Nov 12, 2001 | 02:49 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
I ran SRP in my previous 396 motor. I am going with true J&E with the most recent build up. I want the ability to throw more juice at it later. The SRP are good to about a 200 shot from what I have been told. If you are not going to go more than a 100 shot on the motor, the SRP are an excellent choice.
Old Nov 13, 2001 | 06:04 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
Default Re: building383??what pistons guys?? (Vette92)
I have Speed Pro Hypereutectics in mine, Scat 9000 stroker crank, 5.7 Eagle I beams, you can run a little tighter wall clearance over the forged.
To building383??what pistons guys??
