Ohm's on LT4 Coil ?
Old Sep 17, 2007 | 10:57 PM
Klondike's Avatar
Klondike
Default Ohm's on LT4 Coil ?
Checking for an intermitten multi misfire on My LT4. Took the coil off to check it out. It has a small plug on one side of the top across from the High Volt out to the Opti Dist. The small plug has 3 pins in it. I measured only .3 OHMS between them all. It didn't matter which two I measured between, the reading was the same .3 ohms. Also measured from the HiVolt to the case and got nothing (open). Measured it then to the 3 pins and it was 5.8K ohms. Again it didn't matter which one, they were all the same 5.8K. I don't know what is normal for one of these. Anybody measure one before
Old Sep 18, 2007 | 12:22 AM
jfb's Avatar
jfb
I have an 87, and haven't even measured my coil, but your measurements sound about right. The case is not connected to anything. An impedance bridge to measure inductance and Q is a better measurement, but even better is to pulse 12v to the primary with a .05 Mfd to 0.1 Mfd capacitor across the primary. You can use a capacitor from the old points distributor days. When you disconnect the 12v to the primary you should get a fat spark easily 1/2 inch long from the secondary.
Old Sep 18, 2007 | 06:15 AM
ericcer's Avatar
ericcer
That is within spec according to Autozone. Get your ignition module checked out. Advanced Auto can do that for you.
Old Sep 18, 2007 | 06:21 AM
Tom Piper's Avatar
Tom Piper
Unfortunately, jfb is right; checking the resistance doesn't tell the entire story.
If the coil was open, resistance would tell you that.
But, for example, if one winding was shorted, the difference in resistance would be hard to detect.
As jfb said, impedence checking would be much better.
However, some of that equipment can get expensive.
So, for the average person, coil substitution would probably be the easiest way to check.
Tom Piper
Old Sep 18, 2007 | 09:31 AM
Mojave's Avatar
Mojave
I have my stock ignition control module and fairly new coil (like 1 month old) that I will sell for cheap. I swapped to LTCC and don't need them.
Old Sep 18, 2007 | 10:30 AM
Klondike's Avatar
Klondike
I'll check out the Ignition Module. Got it off for cleaning & regreasing with fresh heat sink compound. There is an Advance Auto just down the road a couple of miles from me too. It sounds like the coil is probably OK. As nasty, expensive and hard to reach as that Opti is, with my luck, that's probably going to be where the problem is
To Ohm's on LT4 Coil ?
