Clang clang?
Old Nov 10, 2001 | 11:51 PM
TIMSPEED's Avatar
TIMSPEED
Default Clang clang?
When I start my car, I hear a NASTY clang clang clang clang. It sounds like it's coming from my bellhousing. Could I possibly have a bad flexplate/torque converter? I REALLY don't wanna rip apart the motor. BTW: This is on my 75 Chevy Truck, with a 350cid/TH350 tranny.
Old Nov 11, 2001 | 12:06 AM
C5Don's Avatar
C5Don
Default Re: Clang clang? (TIMSPEED)
I have an '85 4+3 where after putting the transmission back in had the SAME problem. Turned out to be a VERY slight bend in the plate on the front of the bellhousing. I mean we are talking a ever so slight bend. Have you pulled your starter or anything lately? This is the FIRST place I would check since it is the easiest to fix. And you are correct, it is a real clang and sounds very bad.
Old Nov 11, 2001 | 12:31 AM
want2drivemy85's Avatar
want2drivemy85
check to see if your torque converter bolts backed out, are loose, or are missing.
Old Nov 11, 2001 | 04:13 AM
TIMSPEED's Avatar
TIMSPEED
Default Re: Clang clang? (want2drivemy85)
I put a new starter on not too long ago. What would this have to do with it though?
merrick's Avatar
merrick
could also be a starter needing to be shimmed
To Clang clang?
