help wind noise/water leak
Old Sep 18, 2007 | 02:58 PM
8888vette's Avatar
8888vette
Default help wind noise/water leak
i have and 88 vette the passenger window weatherstrip does not touch the glass on the side of the pillar i tried adjusting the antirattle cushions with no help i dont now what to do next i did notice sometimes i need to shut the door hard to close it can somebody pls explain how to adjust the window or if i need to change the pins on the hinge or the hinge itself
thank you
Old Sep 18, 2007 | 05:52 PM
GeosFun's Avatar
GeosFun
Mine did not have the air gap you describe, but mine leaks in the same area when it is parked in the rain. Ecklers sells a little plastic drip rail that presses into the top that helped some
