What to do (engine mods gone bad)??
Combine this with the fact that I need to get this car emissions legal, and want to be able to drive it. So, what have I done with it?
Coyles double roller timing set, Meziere electric WP, hardened pushrods, pro-mag rocker arms, 8mm plug wires, new style opti, timing chain cover, the GM 222/230 .542/.563 112LSA Cam, and a set of very well done ported and polished heads, with enlarge valves, upgraded springs, retainers, guideplates, etc..
Its a good base to be starting from. My fall/winter project is to get her running well again. I'd like some nice power, but dont need anything insane. Additionally, I'd like it to run WELL. Something I or my wife can hop in, and drive, and enjoy (yes, I learned my lesson the hard way
). Additionally, I think I need a new brake master cylinder. So.. any suggestions on what to do? The way I see it, I have 3 options:1) Pull the cam, replace with something along the lines of the hotcam. Should make some nice power, but from what I understand, the hotcam is nice and tunable, and will pass a sniffer test.
2) Pull the cam, and engine. Rebuild as a 383. Pick a good new cam that fits the 383 well.
3) Leave the cam, and spend the winter trying (once again) to tune it. Unfortunately, this doesn't do much for my emissions problem (unless there is a consensus that this cam could pass a sniffer).
But, if anyone has any other suggestions, I am very open to hearing them!
The traffic is slow over in scan & tune but there are some very sharp guys there.
If you still arent satisfied... I agree go with the LPE211 cam
) Mine passed emissions with it too.I'm surprised you want to the 383 route if this was too much...
As for why I want to do the 383 route- it was my understanding that 383 + milder (for a 383) cam (thus easier to tune) can get you the same, if not better HP gains than a 350 with a wilder cam.
So I guess my first, and biggest priority is to get those brakes working again. I thought it was a brake booster problem, replaced it, to no avail (after bleeding the brake fluid, making sure there was no air in the lines, etc..). So I guess about the only other thing to try on the brakes is the master cylinder.
Randy
-- Joe
