Air Pump vs hp??
Old Sep 19, 2007 | 10:23 AM
saber7469's Avatar
saber7469
Default Air Pump vs hp??
This winter I am planning to do a bit of work on the car ('93 LT1, automatic). I am wondering if I remove the air pump do I save much hp? and I guess is this a good idea? Also what is the weight savings?
Thanks guys, you've all been helpful in the past to this newbie.
Old Sep 19, 2007 | 10:28 AM
CFI-EFI's Avatar
CFI-EFI
It may be a step in cleaning up your engine compartment, but the A.I.R. pump draws very little power. Except for the "clean car" syndrome, there will be no noticeable difference.
RACE ON!!!
Old Sep 19, 2007 | 10:32 AM
rickneworleansla's Avatar
rickneworleansla
I believe your 93 is like my 95 and the air pump is not belt driven. Removing it will not add any horsepower. Removing it will clean up the enigne compartment and may throw a code. I removed mine along with the EGR system when I installed headers.
Old Sep 19, 2007 | 10:46 AM
CoolVette86's Avatar
CoolVette86
From: Partying with the Cowboys cheerleaders in Mt. Olive, New Jersey
RACE ON!!!
QFT.
Old Sep 19, 2007 | 11:11 AM
vader86's Avatar
vader86
Nope.
Old Sep 19, 2007 | 11:15 AM
c4cruiser's Avatar
c4cruiser
LTx motors used an electric AIR pump so you would not see any appreciable gain in HP by removing it. As far as weight, I think the pump is mostly plastic and the hoses are failry thin rubber tubes. Maybe 5-7 pounds total.
If you have to do smog/emissions testing, you will most likely need the AIR pump to pass especially if a visual test is done.
Old Sep 19, 2007 | 11:40 AM
VMAX451's Avatar
VMAX451
It's electric and only runs for a few minutes after cold start up. You wouldn't be hammering on the car under these conditions anyways, so removing it won't do anything horsepower-wise.
Old Sep 19, 2007 | 01:59 PM
saber7469's Avatar
saber7469
Thanks Guys, thanks for taking care of the new guy who's trying to learn.
To Air Pump vs hp??
