msd small cap distributor outer diameter cap please ?
i have ordered #8366 msd dist but have not yet had it sent from jegs yet as im still waiting on other parts,but
i was just wandering if any one could please giver me the msd billet gm small cap distributor out diameter cap measurments please ??
i wanted to know the cap size so i can plan my brass fittings locations on my new 8 t/b intake thats all.
also does it matter which way i install the distribtor with the two plug/wires facing ???, the reason being i might have to face the plugs side on the distributor facing the passenger side and not the other way round that all as my wire harneses may be be a little too short you see...
i know that larry (ld85) has a small cap msd dist may be you can chip in larry please ??
cheers guys
shae
thanks mate for the info on measurements!
the 76 mm you mentioned is that rite around the dist cap edge is it please ?
what i need is the cross section length diameter please ???
as 76 mm round i thought you meant is quite small in size for a dist cap thats all
cheers
shae
Sorry to disagree rodj
OD - Outside Diameter
OAL = Over All Length
