service engine soon light
Old Nov 11, 2001 | 05:06 PM
John Franz's Avatar
John Franz
6th Gear
Default service engine soon light
I have a '95 LT1, and the service engine soon light comes in after driving for a couple of minutes. I own the service manual, but I can't for the life of me figure out what to do to narrow down the problem! Does anyone know where in the service manual to look, or a couple of good places to start looking for the problem? Thanx.
Old Nov 11, 2001 | 06:37 PM
OcalaGuy's Avatar
OcalaGuy
Default Re: service engine soon light (John Franz)
I think you will find out most people will tell you to pull the codes and then post them and they can help you figure it out.
Old Nov 11, 2001 | 06:49 PM
vader86's Avatar
vader86
Default Re: service engine soon light (OcalaGuy)
im not entirely sure how you pull the codes on an LT1, you can get a scanner or take it to a dealer and get them to pull the codes, that will tell you what is wrong with the car. If you could be more descriptive of what was happening to the car and if it had ever done it before we could maybe figure it out.
Old Nov 11, 2001 | 07:01 PM
Red Dwarf's Avatar
Red Dwarf
John, Go to section 8D-1, Book 1. That will give you the info on where to start. :cheers:
Old Nov 11, 2001 | 07:05 PM
OcalaGuy's Avatar
OcalaGuy
John,
Here's a good site with some information that might help you
http://home.fuse.net/c4/ecm_codes.htm
Old Nov 12, 2001 | 12:12 AM
John Franz's Avatar
John Franz
6th Gear
Ok, thanks guys. I looked at that section and thought it only had to do with faults in the Driver Information Center. I got a ECM fault H44, so I guess that would be a "history" oxygen sensor problem.
By the way, does anyone know how easy it is to fix a 'vette with a sledgehammer? :smash: I've owned it for about three months and the only things to break are the power sterring, transmission, seat belt, power antenna, (apparently) oxygen sensor, and (just for kicks) a headlight, a taillight, and two running lights have gone out. Maybe I need to find and disable the automatic 50,000 mile self destruct. *grumble* ;)
I love the damn thing anyway.
'95 triple black convertible
Old Nov 12, 2001 | 02:39 PM
Red Dwarf's Avatar
Red Dwarf
Despite your grumbling, it sounds like your enjoying the experience. Stick with it! :smash:
Old Nov 12, 2001 | 04:31 PM
jerryv's Avatar
jerryv
Default Re: service engine soon light (lou sylvestri)
When my '93 coupe got that message under those conditions, it proved to be an O2 sensor that had fried. When the car would get warm, the computer realized that the O2 reading was way off, and turned on the SES light.
To service engine soon light
