How do I remove The sun Visors???
Old Sep 21, 2007 | 10:30 PM
kowalski340's Avatar
kowalski340
Default How do I remove The sun Visors???
I am looking for step by step instructions on how to remove the sunvisors on my 89 targa...........thanks
Old Sep 21, 2007 | 10:42 PM
RICEKILA's Avatar
RICEKILA
From: Beautiful Down Town "SWINDLEHURST" Long Island NY
Old Sep 22, 2007 | 01:43 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
-remove targa top
-remove plate cap from over tip of visor shaft
-remove spanner (??) nut & spring from tip of visor shaft, careful near end of spanner travle as its spring loaded
-remove screws from header trim under visor area
-press visor shaft down and out of retainer hole
-open electrical connector
-lay visor aside
Old Sep 22, 2007 | 03:27 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Try the FSM
Old Sep 22, 2007 | 11:44 AM
kowalski340
thank you 65ZO1
Old Sep 22, 2007 | 02:23 PM
Da Mail Man's Avatar
Da Mail Man
Originally Posted by vinnies87
Try the FSM
Old Sep 22, 2007 | 05:25 PM
Chatman's Avatar
Chatman
One hopefully helpful suggestion is to use a 10 mm socket and a "Quick-Grip" bar clamp if you have one to press the retaining star washer and spring back into position. I have one that has large pads and is about 12 inches wide when fully opened. It fits well over the exposed bent medal rod of the visor and the other pad goes over the socket. A couple squeezes and its back in place and ready for the nut.
Old Nov 5, 2007 | 06:12 PM
edj37's Avatar
edj37
1st Gear
Originally Posted by 65Z01
-remove targa top
-lay visor aside
Is this for a C5? Instructions don't seem to match what I see on my 2001 Corvette...edj37
Old Nov 5, 2007 | 06:34 PM
USAsOnlyWay's Avatar
USAsOnlyWay
No, its for a C4... you know being that this is C4 Tech...
Old Nov 5, 2007 | 07:05 PM
65Z01's Avatar
65Z01
They are for my '88 in particular but I believe apply to all C4s.
To How do I remove The sun Visors???
