Instructions for Install for Trans Cooler
Old Sep 24, 2007 | 09:15 AM
Brett Richmond's Avatar
Brett Richmond
Default Instructions for Install for Trans Cooler
I bought a Trans cooler form a member, but it came with no instructions, does anyone have a link or could copy some that they have and post them. I want to make sure I do this install correctly.
Old Sep 24, 2007 | 10:19 AM
Aardwolf's Avatar
Aardwolf
This is no one right way to do this, there are a bunch of options. Here is how I installed mine:
AN fitting on the radiator and the other line pushed onto the stock flared hard line.
Metal straps for mounting, using the bolt holes from the aux fan which I removed.
Total cost was low and install time was short.
Old Sep 24, 2007 | 11:45 AM
rickneworleansla's Avatar
rickneworleansla
Here is mine.
Old Sep 24, 2007 | 01:54 PM
Brett Richmond
So it is like I thought it was, pretty straight forward in the installation part. I just need to get the right fitting for each end and find the best place for it.
Old Sep 24, 2007 | 03:08 PM
Aardwolf's Avatar
Aardwolf
I used this 1/2" inverted flare to 6 AN adapter from Summit on the radiator:
Then put the above 90° bend for hose barb onto it.
Old Sep 24, 2007 | 07:38 PM
Z06_BluByU's Avatar
Z06_BluByU
I went with the B&M 11"x10" stacked plate design.. I custom fabricated brackets to make sure it sat +/- 3/4" off of the condensor (it does not touch it at all) and about +/- 1/2" off of the top housing..
The weird thing about this cooler is the air doesn't pass straight through.. It is deflected at about a 30* angle as it goes through the cooler.. so to get the airflow right the fitting lines face the opposite side of where the tranny lines are.. I wanted a clean install and worried about chaffing etc.. with using just rubber lines.. so I hard bent some brake lines... Getting the correct fittings for this was a trick.. but after several trips (lots of trips) to the hardware and auto parts store I finally got everything I needed.. Feel free to ask questions.. I'm not sure how much this will help.. but you can feel a big temp difference between the intake and the exhaust lines!! I bought a gauge to install but I dont think i'm going to.. the A-piller pod mounts just dont do it for me.. and besides.. its not like I could do anything to make it any cooler...
Oh and this cooler runs in series with the radiator tranny cooler.. (first the fluid goes through the radiator and then through this cooler)..
Pix:
Old Sep 24, 2007 | 08:49 PM
Stefan Nord's Avatar
Stefan Nord
I have 2 coolers, 1 for trans and 1 for engine oil
The trans cooler is a big one and I dont use the original anymore, just hooked the hoses from the new cooler to the original metal pipes.
http://www.vetteforum.org/attachment...7&d=1187273837
Engine oil cooler:
http://www.vetteforum.org/attachment...2&d=1187273436
http://www.vetteforum.org/attachment...5&d=1187273733
http://www.vetteforum.org/attachment...6&d=1187273816
To Instructions for Install for Trans Cooler
