C4 Wheel balance
Low and behold the service manager took one look at my tires and said he could not help me as my tires were too wide and whenever they had tried to balance a vette they ran into trouble. He said I should take it to the dealer. ( I'd hate to think of the cost of doing that)
Whats the deal with this ? The tires are wide but nothing extraordinary. Is there a real reason behind his action ?
Will I run into this with most tire shops ?
Any decent tire shop should be able to handle it, but the dealer would be one of the last places I'd go. I've actually gone to an good import service center before, they handle large size wheels/tires all the time and do a good job.
Around here even Sears can put them on. Call around first.
After many attempts at balancing that failed, the Hunter Road Force machine worked miracles.
That's because it is more than a balancer, when done properly by someone that knows how to use it, it eliminates runout and other vibration related problems. Balance is only one aspect of eliminating vibration.
Tom Piper
The local Firestone dealer here has a Hunter Road Force Balancer, and they have personal that know how to use it. They did a great job on my car.
Keep looking until you find a shop that knows what their doing.
I found even if they do it correctly, it only last for 6 months, then the wheel starts shimmying again. The best solution is to trash the offending tire.
anybody wants to buy some tires real cheap
I have posted a request in the Great Lakes regional forum for recommendations in the Columbus area. Someone will know of a good shop in Columbus.
I too have found that often the techs are not as skilled as the machine. In my opinion, this is especially true with the Hunter Road Force balancers. If the machine isn't calibrated regularly and accurately by a well trained tech, using it is a waste of time.
After dealing with a well known shop that obviously wasn't properly calibrating their Hunter, I found a local shop that will run the wheel on the balancer and then if the amount of weight required is too much in their opinion, they mark and then depressurize the tire. They rotate the tire and try again until the very minimum of weight required is found. Then that weight is added and the wheel road force tested. The difference is night and day. The car rides smooth, as if on rails and the balance lasts a long time.
A lot of new car dealers are getting the Hunter machine.
I have found that dealers invest more time in training their techs than the local discount tire shop.
But, one thing important to keep in mind is a regular balancing machine ONLY deals with balance -- nothing else.
The Hunter machine does balance and much more.
There is more to tire vibration than balance -- regardless of how much weight or how the weights are installed.
One of the biggest problems with someone trying to get a "road force" vibration analyzation (notice I didn't say balance) is they do it after they buy the tires somewhere else.
Not all tires will "true up" on all rims.
If you buy the tires at the same place that is doing the road force and one of the tires will not true up on your rims, they will put that tire back on the shelf and pick one that will.
If you buy the tires somewhere else and the tire will not true up on your rim, they aren't going to swap it with their stock.
They will do the best they can with what they have and call it a day.
I had a set of tires that I attempted to get balanced about six times with no success.
One trip to the Hunter machine was like heaven.
Tom Piper
I had one tire on a work van, where they matched it to the rim, and the van still shook like crazy. Even though the hunter machine matched it, still had the virbration...
Companies like AFS wheels that sell their new rims with tires already mounted use road force.
The ones that don't make it, are sold at internet auctions.
Tom Piper
