700r4 won't shift
Old Sep 26, 2007 | 08:22 AM
htrdbmr's Avatar
htrdbmr
Default 700r4 won't shift
'91 700r4, I have to lift to get 3-4 shift. 1-2, and 2-3 shift at 5200, but 3-4 will not shift (I've seen 5800 before lifting) All else seems well otherwise. Thoughts?
Old Oct 22, 2007 | 11:06 PM
crop's Avatar
crop
2nd Gear
Default govenor
on the side of trans, there is a hub that you carefully pry off and replace govenor. Or your TV cable needs adjusting.
Old Oct 23, 2007 | 07:45 AM
Brimis's Avatar
Brimis
TV cable doesn't get adjusted, its gets set.
Old Oct 23, 2007 | 09:44 AM
Pete K's Avatar
Pete K
Blocked govenor screen, hung up valve in the governor, worn axle pins in the governor or "apple cored" governor gear are all possibilities. The gear is the likely cause.
To 700r4 won't shift
