low temp fan switch questions please ??
Originally Posted by larryfs
where would you find such a sensor ?
I havn't seen any in that temp rage.
the GN is 203 on, ??? off.
Originally Posted by CentralCoaster
CFI, my experience with 2 high flow RobertShaw 180F thermostats, and someone else's, is that they are substantially open by 175F.
I think he'll be fine with a 185F off and a 180F high flow stat.
RACE ON!!!
do u know the spread on a typical GM fan switch? I think it is 16 degrees, but never saw it documented.
Even the 89 shop manuals are full of typo's. the temps are listed in C, and some of the conversions to F are just wrong. This is in the F-body manual I have for 1989.
I don't know of there is a typical, or standard "On" to "Off" temp spread. When I bought my switch, i selected it from a catalog of stock switches. I looked up the stock switch, then in the numerical listing, in the back of the book, I checked the specs for the stock switch. Finally, I went through the numerical listing looking for specs that matched the stock switch, especially the connector, with a temp setting I could live with. I don't recall both the on and off temps being listed. All I remember seeing is the "On" temp.
RACE ON!!!
RACE ON!!!
I feel the off temp is equally as important. I don't want to fans running when I'm crusing down the highway.
On the 89 ECM, when the AUX switch closes, doesn't that feed back to the ECM to kick on the primary fan ?
BTW, my '84 has no aux fan (wasn't available) and the main (only) fan is controlled by a thermo switch in the head like the aux fan in the 1985 - 1989 cars. On my car the ECM has nothing to do with the fan.
RACE ON!!!
