replacement time
Old Sep 30, 2007 | 03:45 PM
finally_got_it's Avatar
finally_got_it
Default replacement time
im replacing injectors, and was told by a friend of mine that i should go with the 24lb lt4 injectors. Is that a good idea and if so where is the best place to get them? any other injector recommendations?
Old Sep 30, 2007 | 06:47 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
The LT4 had 28lbs/hr injector LT1 used 24lbs. The Ford SVO injectors have been very popular, no personal experience just what I've read on here.
Old Oct 1, 2007 | 01:58 PM
ScaryFast's Avatar
ScaryFast
A set of 8 FMS injectors is about $250. Lots of guys here use them. I personally have the 30# version for my 383.
Be careful if you go that route, though. Sometimes they stick when new. If you install them and the car runs rough that's probably the case. Just find out which one and knock it a little until it frees up, it's no big deal if you're expecting it. When I installed mine I looked everywhere else for my problem, figuring that it couldn't be the injectors because they were brand new.
To replacement time
