Engine coolant temperature display reading low all the time
Old Nov 12, 2001 | 09:20 PM
N.Robert's Avatar
N.Robert
Cruising
Default Engine coolant temperature display reading low all the time
Hello everyone, I am puzzeled about the temp. display allways reading Low. The oil temp reads between 180 and 200. I changed the coolannt temp. sensor and inspected the wiring. Still no reading on the dash display even though the rest of the displays are operating normaly. Has anyone ever had the same problem? Any ideas for a solution. :confused:
Old Nov 12, 2001 | 10:02 PM
vette87's Avatar
vette87
Default Re: Engine coolant temperature display reading low all the time (N.Robert)
What temp thermostat are you using? Mine was stuck open and my temps were lower than that about 150 or so. After installing a 180 thermostat it runs in the 175 -180 range.
Old Nov 12, 2001 | 10:16 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Temp sensor for the digi-dash is on the passenger side, I believe between #6 and #8 - just above the starter. I believe an open circuit will cause it to always read low (as if disconnected).
Old Nov 17, 2001 | 05:36 AM
N.Robert's Avatar
N.Robert
Cruising
Default Re: Engine coolant temperature display reading low all the time (PeteL)
Still reading lo, I cannot find any sensor between #6 and 7, please help :confused: The thermostat is new and comes on around 170-180, Oil temp rarely goes ubove 200.
[Modified by N.Robert, 3:43 AM 11/17/2001]
Old Nov 17, 2001 | 04:16 PM
JAKE's Avatar
JAKE
On the 86, it's located on the passenger side cylinder head NOT the driver's side head. If you have it installed on the wrong head your gauge won't work properly.
The driver's side location is for the fan. Haynes manual has it backwards and has caused a lot of guys problems, including me.
Between 6 and 8 not 6 and 7.
Jake
To Engine coolant temperature display reading low all the time
