LT1 intake on L98
Old Oct 1, 2007 | 05:59 PM
clevette's Avatar
clevette
Default LT1 intake on L98
I just picked up an lt intake to have monified and put on my 85. Is it really worth the trouble? Am I better off on sticking to the TPI?
Just looking for some opinions
Also who is doing the mods? I heard Lt1intakes is no longer doing them.
Gary
Old Oct 1, 2007 | 07:13 PM
Mojave's Avatar
Mojave
Gary
If you want more power, it is definitely worth the effort.. Stock TPI is quite restrictive.
Old Oct 1, 2007 | 07:14 PM
Draven's Avatar
Draven
St. Jude Donor '14
Do it.
Do a cam and rockers at the same time.
Old Oct 1, 2007 | 07:17 PM
JAKE's Avatar
JAKE
Gary
Check on he Camaroz28.com Forum. There's a guy there named Bret Bauer who may still do them. If not, he/they can point you to someone who does.
Jake
Old Oct 1, 2007 | 09:58 PM
CorvAdel's Avatar
CorvAdel
Originally Posted by Draven
Do it.
What cam do you recommend if all else is stock, inc. A4 and 2.73 rear?
What about with heads flowing, like 215 int.@.500, 3.07 rear and free-flowing true dual exhaust..?
Old Oct 1, 2007 | 10:03 PM
vader86's Avatar
vader86
Cam choice depends on alot more things, what are you looking for from the engine? Bear in mind that an 85 remains hyd. flat tappet, not a roller cam.
I would take the LT1 intake over the TPI in general, but that also depends on what you want from the engine.
Old Oct 1, 2007 | 11:41 PM
Demonic85's Avatar
Demonic85
If your gonna put an LT1 intake on there its beneficial to have higher gears like 3.54 or even 4.10 but thats if your really serious. This will help it get to the power band quicker. 2.73 kinda sucks even for TPI, i've got a 3.07 in mine which is supposed to be good for it.
I particularly like the Lunati Voodoo cams, but like Vader said it can vary quite a bit.
Old Oct 2, 2007 | 08:51 AM
rodj's Avatar
rodj
Gary
An decent machine shop could do the mods.Not rocket science if they have a stock manifold to work off.
Drill 2 holes for water outlets , machine intake for dist and redrill intake bolt pattern.
Old Oct 2, 2007 | 01:04 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
I've got the chevy cad files for a stock intake if you need the measurements.
Keep in mind LT1/4's have a different bolt pattern.
Also a miniram is always an option, just a little more $$$
Old Oct 2, 2007 | 03:47 PM
dock351's Avatar
dock351
St. Jude Donor '06
I got my LT1 intake conversion done by Adams Holzhouse, (Sp) who lists on ebay. He did a pretty good job as we have found so far.
Issues so far: throttle line and TV line shortened; location of external T-neck; ECT sensor fitment, grinding the intake bolt holes, fuel lines, coolant hose routing, vacuum lines. Most all of this is described on www.lt1intake, as well as various forums such as third gen , camaro z28
Old Oct 3, 2007 | 07:28 PM
gear-head2's Avatar
gear-head2
LT1 vs. L98 depends on what you want.
L98 is all done by 4500 rpm
LT1 is just waking up at 4000 and loves to go to 6500 rpm.
Look at the whole package and match the intake to the rpm's you are looking for.
Old Oct 3, 2007 | 08:48 PM
redrose's Avatar
redrose
will never go back to tpi...have an lt1 intake presently on a 355 ci and previously ran one on a 406 (sold the whole thumper, actually a 400+o.040 = 409 for an offer i couldn't ref, cookin a new one)...like a totally different car with the lt1 intake vs the tpi on both...you can shift the tpi when it ''flattens out'' but with lt1 intake be careful to NOT over-rev, things happen sooooo much faster.
local shop was doing the conversion, numerous improvements from typical other set-ups... stopped, but grapevine sez they're back...will advise if you'd like.
Old Oct 3, 2007 | 09:51 PM
Danspeed1's Avatar
Danspeed1
This is something I seriously intend on doing after I do either heads and cam or a full rebuild.
I like the L98 TPI with my 3.54 gears because it gives instant gratification. Lots of torque. I don't know how changing to a LT1 will effect your toque curve... but in my 96 Impala, with the LT1 it only starts to wake up around 3500 even though the car is supposed to make it down low.
Maybe some of you guys could chime on what happens to torque and horsepower curve.
In any event, I think a set of gears would be much more beneficial,... I like my 3.54's
DG
To LT1 intake on L98
