Removing rubberized coating on plastic
Old Nov 5, 2007 | 03:48 PM
rickneworleansla's Avatar
rickneworleansla
Originally Posted by pr0zac
what if you clear coated a brand new one with the rubber still on it??? how do you think that would work.. mine is 2 years old and looks worse now then the one i replaced. i drive my car almost everyday.. so having that part out for a few days would drive me nuts..
I'm not sure how the rubber coating would react to it. Probably not well. Maybe someone who hasn't stripped theirs yet could try. I have driven without the console for a while. It looks but it's still functional. Something else I haven't heard anyone mention but I was tempted to try was light media blasting to remove the rubber. There are many types of media for removing different substances. I guess there is the possibility of it heating up too much or warping the plastic. I am media blasting my other car right now and may decide to experiment with it.
Old Nov 5, 2007 | 04:48 PM
LouisvilleLT4's Avatar
LouisvilleLT4
No, no, no. The whole point is that the rubber gets nicked up irreparably as the car gets used; clearcoat will not protect the rubber from getting chipped off, and will most likely not adhere to rubber at all. At best it would make a once stock-looking brand new part unnaturally shiny. You would already have the pieces off to treat them, why not just do it the right way? Chemically stripping your old pieces and doing the procedure as above takes about an hour if you have the paint, clearcoat, gasket remover, garden hose, and sandpaper ready and on hand. There would be no reason for that part to be off of your car for a few days as you feared, provided that you know how to remove and re-install the parts and don't waste a ton of time figuring that step out.
Old Nov 5, 2007 | 05:17 PM
schrade's Avatar
schrade
Originally Posted by Red Dwarf
This is from Tech Tips. https://www.corvetteforum.com/techti...=114&TopicID=2
In the future you may save some time & money by searching thru the Tips section.
You think so, huh???
That shoppin' list at the beginning looks like $75 - $90. My soapy water is about $1.15.
Old Nov 6, 2007 | 09:03 AM
LouisvilleLT4
Yeah the tech tips section in general sucks pretty bad, and I hate it when people like this guy pompously assume that what's in tech tips is better than what you wrote. I highly doubt he even read it before he linked to it.
edit: sorry, I was pissed off at something else when I typed this.
Old Nov 6, 2007 | 11:01 AM
NEVRL8T's Avatar
NEVRL8T
Old Nov 6, 2007 | 12:25 PM
schrade's Avatar
schrade
He meant well, just didn't do a very good job.
I washed most of it off with soap and water, then put a lint roller to the rest. Clogged up the lint roller with each pass.
Still got one spot (left, below radio) playin' hard to get. It don't look good, but it's clean, and I'll get over it.
Old Nov 6, 2007 | 02:17 PM
93cruiser's Avatar
93cruiser
Originally Posted by black_771
I tried other stuff like acetone and mineral spirits but it really softened the plastic too much. If you scrape on it you ended up gouging it badly.
A small wirewheel on my dremel didn't do much either.
Sanding didn't work for me at all. The rubber ended up gunking up the paper and never took the rubber all the way off anyway.
Soapy water takes forever, but it worked the best and left everything nice and smooth for painting.
When I repainted my console bezel, I was able to peel the rubber coating by rubbing the part with a rag soaked in Acetone. I then peeled it off using my fingers and dry rags.I did sand it also to remove some of the surface defects from the molding process.
It is still a lot of work.
93cruiser
Old Nov 7, 2007 | 05:00 PM
JA94vette's Avatar
JA94vette
I did my interior...here are a couple of pics...sorry I though I had some better ones, I'll take a few when I'm home in a couple of weeks.
Old Nov 7, 2007 | 05:16 PM
black_771's Avatar
black_771
Originally Posted by fc_soldier
Im def. going to do this cause I ended up somehow getting a nick in the coating. I might send mine to a paint shop to get a professional to paint it and clear coat it a couple of layers. We'll see if the price is right.
If you paint it with flat paint, it's almost impossible to mess up unless you get a run. Flat paint goes on nice and even.
Old Nov 7, 2007 | 05:38 PM
biggrizzly's Avatar
biggrizzly
2015 C5 of Year Finalist
Looks awesome
Old Nov 7, 2007 | 07:10 PM
schrade's Avatar
schrade
So ja40, did they spray the trim when you got the car sprayed? How did they hold the parts there?
