Interior Carpet and glue question
Old Nov 13, 2001 | 10:58 AM
-=Jeff=-'s Avatar
-=Jeff=-
Default Interior Carpet and glue question
What type of glue is used on the carpet for the console and dash? or what can I use that will be just as good?
Old Nov 13, 2001 | 11:22 AM
a851yy07's Avatar
a851yy07
Default Re: Interior Carpet and glue question (-=Jeff=-)
When i replace my carpet i just used a 3M spray adhesive. has been holding just fine for the past two years.
Don
Old Nov 13, 2001 | 12:04 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Default Re: Interior Carpet and glue question (a851yy07)
I used the 3M spray can glue..works great,BUT I also used some 3M yellow weatherstrip adhesive with it for the middle parts to hold better.Then use the can spray for getting closer to the corners and edges.
Using weatherstrip glue too close to the edges will push out.
They sell 2 kinds of 3M can sprays..one is heavy duty and isnt recommended for thin carpeting...can bleed through.I used the thinner kind thats recommended for carpets and thin trims.
It will say so on the can.
Great stuff.Just dont inhale the fumes.
:D
Old Nov 13, 2001 | 08:46 PM
gh86E's Avatar
gh86E
There's only a few places you even need adhesive - to hold the carpet onto the console side panels, and onto the knee panels on the underside of the dash. Adhesive wasn't used, and wasn't needed, anywhere else on my '86.
I tried the 3M spray adhesive on the passenger knee panel (which hangs upside down). I replaced the carpet without removing the panel (which seemed like a big job). Two days later was a hot day. I came home and found the new carpet lying on the passenger floor. So the spray adhesive was too weak. And it certainly wouldn't hold the heavy mass-backed carpet panels to the console side panels.
Two things I found - getting the knee panels out wasn't as hard as I thought, and Pep Boys sells a 3M fast tack trim adhesive which DOES work (see the 'Resto tips on my web site below for how to get the panels out and back in, and the adhesive to use).
Old Nov 13, 2001 | 11:33 PM
Aggravated4life
Default Re: Interior Carpet and glue question (gh86E)
Hey Greg,
Something caught my eye..did you say you had "mass backed console panels"?
If so, wow, I didnt know they made them like that.Usually every carpet in a kit that is mass backed(if you order that type)is covered, except the console pieces and the dash pieces.The transmission tunnel wall before the trunk starts,behind the seats, GM used a cheap thin rug while the kit DID come mass back for that.The spray can will not work there for sure.Lotsa glue and 2 pieces of wood,and 2 wood C clamps to clamp the carpet down over the sill and let it dry 24 hours.That worked fine for me.
At least in my case, my GM carpets and my new replacements had no mass backing on the dash or console.They were very thin with some kind of thin white plastic backing.
But still thicker then the originals.
I knew the spray alone wouldnt work,so i used the 3 yellow strip glue and used that going back and forth more in the middle areas and the spray glue nearer the sides,as I mentioned before.I did this because the GM carpets had some kind of stretchy rubber glue on the back of the original carpets.Figured this would hold it much better and has for 3 years now.
Did you have that as well?
Just wondering since I have an 86 as well.
Yeah, I can imagine on a real hot day with just using the spray adhesive, it can heat up and melt and cause the carpets to pull away.
3M yellow glue is pretty good..but I wonder if it crystallizes over time.But so far so good.Any thoughts on your experience?
Old Nov 14, 2001 | 01:31 AM
Aerovette's Avatar
Aerovette
There has only been ONE occasion when 3M spray adhesive has NOT worked for me. I have used it for speaker cabinets and carpeted 4 different Corvettes with it. I even inlaid a bowtie in a friend's carpet using ONLY 3M spray. The key to it holding for life is...spray BOTH surfaces, wait several seconds for it to get tacky, and BAM, it WILL stay. If you spray only one side, or you don't wait several seconds, it will more than likely not work well. :seeya
Old Nov 14, 2001 | 01:45 PM
gh86E's Avatar
gh86E
Default Re: Interior Carpet and glue question (Bill's86Coupe)
Hey Greg,
The 3M Fast Tack Trim Adhesive worked fine so far. The heavy carpets are still hanging on on the knee panels and console side panels. Didn't need anything more than the fast tack adhesive for the side panels. Didn't need to clamp it. I actually took the newly-installed carpet off one side panel (when I found a better condition side panel), and it was on pretty solid. Try to get some globs of glue on the console panel, and an even coat on the carpet - that worked pretty well for me.
As for the carpet, the original GM carpet that came off was like you described - most of it, incl. knee panels and console side panels, just had a thin plastic backing. Only the rear hatch center piece (and maybe the side pieces) had mass backing.
I bought my carpet from 1aauto.com, which resells ACC carpet. But they sell a heavier version called 'Custom Comfort' material. This is a denser weave than original, and supposedly will resist fading and wear better. It looks better than the original carpet too, not as scraggly. I don't know if any other ACC resellers sell this thicker material. But I'm happy with it. EVERY piece had heavy mass backing. Very little cutting and trimming was required - ACC had done a mostly good job. I wasn't sure the thick (and I mean thick) knee panels would fit up under the plastic dash, but they did. The door sills also fit, although tightly (from the thickness of the floor area carpets).
To Interior Carpet and glue question
