Intake gaskets
Old Oct 3, 2007 | 02:21 PM
TPeye's Avatar
TPeye
Default Intake gaskets
I'm in the process of reassembling my L98, and may have run into a problem. The factory intake manifold gaskets had small holes for the coolant passages, but the Fel Pro 1205 that I bought as replacements have large holes. Will this lack of a flow restriction cause any cooling problems?
Old Oct 3, 2007 | 02:59 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
No.
Old Oct 3, 2007 | 05:37 PM
Bossman89's Avatar
Bossman89
My felpros were cut like yours and they do just fine.
Old Oct 3, 2007 | 06:12 PM
Aardwolf's Avatar
Aardwolf
I have the 1205 on mine as well with no trouble. If you run a search there and many many posts on the 1205. Reading back it looks like some have blocked off the rear coolant port and removed the small line tee into the heater core line.
Old Oct 3, 2007 | 10:48 PM
chucks88's Avatar
chucks88
Are the 1205's subtable with the stock heads? (if that's what you have)I though 1204's were used(again, for stock heads)
Old Oct 4, 2007 | 09:37 AM
Aardwolf's Avatar
Aardwolf
I have stock heads on mine, when I changed gaskets it was when I was putting the big mouth base intake on.
To Intake gaskets
