Intermittent stall from idle.
Old Oct 3, 2007 | 05:58 PM
Ernest's Avatar
Ernest
Default Intermittent stall from idle.
My '92 6 spd. has started to stall after driving it for awhile. If I stop at a light it cuts off. Then I have to restart and keep my foot on the gas. I was looking for a vacuum leak to no avail. It does not do this all the time,only long enough to drive me crazy.
Old Oct 4, 2007 | 02:13 AM
BAM92's Avatar
BAM92
Sounds like the IAC valve in the throttle body. Sometimes you can pull them out and clean them. They get a build up in them and start to stick. Otherwise replace it.
Old Oct 4, 2007 | 11:14 AM
90coupewithlowmiles's Avatar
90coupewithlowmiles
I have a like situation with my 90 with 50k. My car is at a local shop now and I will let you know (not that we may have similar problems) the outcome.
Best of luck.
Old Oct 4, 2007 | 11:51 AM
Vito.A's Avatar
Vito.A
I replaced the idle air control (IAC) and that solved my problem. They are under $50 and easy to replace.
Old Oct 4, 2007 | 11:59 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The IAC motor connector is located under the RH side of the TB.
The procedure to reset base idle is on my site; just ignore the part about setting the TPS as your's isn't adjustable.
To Intermittent stall from idle.
