I just got my motor back from the machine shop and all the parts can you guys tell me what you think of the setup and guesstimate the hp these are the parts I'm using if I forgot something let me know
com cams 08-432-8 gross lift = in .510 ex .520 duration @.050 in 230 ex 236 Lobe separation 110.0
OE style roller lifters
Mahle power pack forged pistons
6" I beam rods
Scat 935060L 383 crank
10:1 compression
4 bolt main block
2400 rpm stall
3:54 rear gears
I already have a hi flo cat with flowmasters and the ecu is programmable I'm using the SDS ECU I don't have my injectors yet but I am planning on using the SVO 30 pph this is in an 87 L98 coupe can you tell me what you think about this setup good and bad thank you in advance
Get a hold of 88BlackZ51. He has polled every engine parts combination possible and probably a few that aren't. He can tell you the horsepower and the ET down to the tenth, of any and every C4 ever assembled.
CFI-EFI knows that I am the master.......However he is my little jedi that I am training. I just took a washroom break and I walked into my computer room to check my emails, and check the forum and was asked to comment on this combo. However, I must go back and watch my hockey team kick some butt! GO LEAFS GO!!
Time to shut the computer off. Goodnight CFI-EFI. Sweetdreams!
To the thread started. Looks like a good combo. 10x the combo that CFI has in his old bucket of bolts 84 car. As you can see good old ****box CFI ruined another thread. Take care!
vetteset8087: What is your estimate of your HP. It's very hard too estimate because only you know how well the computer will be tuned. It's a challenge, Goodluck mate!
So YOU made me do it. Master pest maybe, or baiter. Every time anyone ever posted an engine combination, "What horsepower did it make?? What does it run in the 1/4?". Then as he daydreamed various engine set ups, he asked, "What horsepower will this make? What will it turn?".
I should hope so. Mine hasn't ever been worked on.
With a good tune that car will rock. Most guys seem to recomend proven combos that are pretty tame. I have a milder motor with a Miniram that I got this summer. Wish I would have done it 4 years ago. Let us know about those Brodix heads. They are looking better all the time.
