need some help
Old Oct 4, 2007 | 09:33 PM
corvette8189's Avatar
corvette8189
Default need some help
well on my way home tonight my service engine soon light came on anybody know what could be up. im suppose to be going on a little trip tomrrow so help would be appreciated.
96 vert a4 105k miles
Old Oct 4, 2007 | 09:57 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
There are lots of things that could make that light up. You need to actually find out what code got set, so you'll know where to start.
The light came on because one of the sensors detected an out of range condition. I believe AutoZone will read the codes for you for free.
Old Oct 4, 2007 | 10:21 PM
corvette8189
anyway i could read them. somebody told me there was some way but anybody know?
Old Oct 4, 2007 | 11:16 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
corvette8189,
yes there is. and it's easy. do you have a factory service manual (FSM)?
If so, look for the Central Control Module section (in our 94 FSM it's section 8D). The first section or two discusses the 'diagnostic mode' and how to engage it (on our 94, it indicates grounding pin #12 of the ALDC connector (under the driver side dash).
HOWEVER, since yours is a 96 and has both the OBDII connector and is OBDII compliant, I am resonably sure it will be different pin grounding on yours...
If you don't have a FSM, check the tech section, or do a search to find how to do it.
Old Oct 4, 2007 | 11:43 PM
theadmiral94
been looking for how to pull codes for 96, and didn't find yet (in case you don't have a FSM).
Anyway, in case you find how to pull the codes, here is a link to the codes: http://www.corvetteactioncenter.com/...+Trouble+Codes
Old Oct 5, 2007 | 12:11 AM
corvette8189
thanks and ya i dont have a fsm and looked but i cant find anything either
Old Oct 5, 2007 | 05:04 AM
runner140*'s Avatar
runner140*
Most good parts stores will test your computer for codes for free. AutoZone and Discount Auto Supplies have that service down here.
Old Oct 5, 2007 | 09:20 AM
corvette8189
alright got it tested and it said random/multi missfire
the guy said i probally need a tune up
i just bought the car a couple of months ago so who knows how long its been.
any other suggestions
Old Oct 5, 2007 | 09:41 AM
runner140*'s Avatar
runner140*
And you're going to take it to a dealership to get it taken care of?
Old Oct 5, 2007 | 01:54 PM
CFI-EFI's Avatar
CFI-EFI
Get a FSM and follow the trouble shooting chart for the code you found. It will help you diagnose the cause and lead you to the repair.
RACE ON!!!
Old Oct 5, 2007 | 02:06 PM
corvette8189
ya gonna get a fsm soon but for now im gonna give it a tune up but i also heard it could be the opti
Old Oct 5, 2007 | 02:19 PM
CFI-EFI's Avatar
CFI-EFI
Atta way to throw money at it. Soon, you will have PAID for a FSM, without getting one.
RACE ON!!!
Old Oct 6, 2007 | 12:14 AM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Default Obdii
Just a guess on your check engine light. How about just a little bit of water/condensation that was in the gas tank. This activated the check engine light in my 96 LT4, not driven enough for sure. Anyway went to Auto Zone and the code was for the front drivers side oxygen sensor. I kept driving the car to see if it would develop another stumble. Was really surprised when driving down the road the check engine light just went out on its own. Like I mentioned, don't drive the car enough, so to really check it out I removed the gas cap filler neck/fuel pump so I could do a visual inspection inside the tank. No moisture. This happened last year, still not driving it much, did put about 800 miles on it last month on a trip, no problems. To my knowledge without a scanner, you are not going to get any codes like earlier Corvettes out of a 96 Corvette OBDII. My 96 LT4 was bought new and has not had a tune-up yet with about 38K on it now. Only thing that has been changed is the coolant.
Old Oct 6, 2007 | 02:15 AM
bogus's Avatar
bogus
For the sake of review, the old school jump the pins doesn't quite work well on the ODBII equipped 96's... the codes are just too damned long to work with. You can't read them on the speedo, and at 3 and 4 digits, reading them by flash is a pain in the ***.
with that said, the random misfire can mean any number of things. do you know the specific code? P-what?
Now... if at 105k miles, it is still running (by some miracle) with the OEM plugs, I would swap them out. The stock Delco Platnum Plugs are JUNK. Utter and complete JUNK. They have these little platnum pucks on the ground strap... it falls off... or burns off, who knows... either way, it's gone, and the gap grows from .050 to .065. That can easily cause a misfire. And ODBII is so much more sensative about it.
Old Oct 6, 2007 | 06:07 AM
Da Mail Man's Avatar
Da Mail Man
Old Oct 6, 2007 | 06:08 AM
Da Mail Man
RACE ON!!!
Old Oct 7, 2007 | 06:46 PM
corvette8189
well i havent done anything yet and the light will be on and then it will go off for a day then come back on.
To need some help
