check this out
Old Nov 13, 2001 | 06:35 PM
PylonBoy's Avatar
PylonBoy
Default check this out
my crappy old clutch
oh yeah, clutch was like 3k miles old
don't buy centerforce
Old Nov 13, 2001 | 06:45 PM
BobMachus's Avatar
BobMachus
Default Re: check this out (PylonBoy)
I know a few people who have had centerforce issues, mostly on trucks.
Old Nov 13, 2001 | 07:18 PM
ZylaRace's Avatar
ZylaRace
Waz-up sit dat? You beat on it? R they gonna warrenty it?
Old Nov 13, 2001 | 07:59 PM
RichS's Avatar
RichS
Default Re: check this out (ZylaRace)
My centerforce is working great! Either yours was installed wrong or something else is causing the clutch to engage partially causing it to slip. (Or you really don't know how to drive a stick :jester :jester ) :D
Old Nov 13, 2001 | 08:16 PM
bogus's Avatar
bogus
the factory clutch in my old prelude wore out. but as bad as that was, it doesn't come close to yours...
My preludes clutch lost a couple of the center springs... messy, yes, but still functional!
Old Nov 13, 2001 | 09:00 PM
GlockLT4's Avatar
GlockLT4
YIKES!!! SOmeone burned their clutch up nice and good :eek: :eek: :eek: :eek:
Old Nov 13, 2001 | 09:49 PM
EricVonHa's Avatar
EricVonHa
How many times did you hold the brakes to the floor while at the same time matting the throttle in first gear attempting to light off the rear tires for some insane burnout??
Old Nov 13, 2001 | 10:42 PM
PylonBoy's Avatar
PylonBoy
Default Re: check this out (EricVonHa)
never.
I bought the car with the clutch. The clutch was never abused. It failed on an easy shift, not a dump.
Old Nov 13, 2001 | 11:49 PM
CAPN17's Avatar
CAPN17
If the CF cluth is not broken in properly for the 1st 500 miles it will go to hell quickly afterwards. It appears that the fellow who put it on did not break it in as recomeded. Mine has behaved it self just fine afer breakin.
Old Nov 13, 2001 | 11:52 PM
PylonBoy's Avatar
PylonBoy
Default Re: check this out (CAPN17)
the guy did agree with that opinion until he saw the clutch. And you are right, he didn't do proper break in proceedures. Instead of 500 miles, he did it for 2500 miles. This clutch was not abused. Untill this clutch the guy saw no problems with CF.
Old Nov 14, 2001 | 04:49 AM
Turismo's Avatar
Turismo
HAHAHAHHAH! How do you break in a clutch?
Old Nov 14, 2001 | 04:00 PM
NavyVet's Avatar
NavyVet
I wish I had pictures of mine. Exactly the same thing happened about 450 miles after installing it. It blew on a shift at about 5500 RPM. One of the huge pieces of friction material (like in your picture) stuck between the rest of the disk and the flywheel, locking up the whole drive train. Result: broken right rear stub axle, wheel came loose and tore up the caliper and bracket, brake pads, rotor, etc. CenterForce (through Exotic Muscle who did the work and repairs - fantastic job Merle & Trevor) covered everything. CF inspected the debris and told Merle @ EM that it was a defective disk. They made it good! Absolutely no problems since and I've made 80+ autocross runs since. There was at least one other disk sold at the same time that had the same result (CA I think). Contact CF and I'm sure they will make it right for you.
To check this out
