Every since I got my car back on the road i've had a problem with my 4+3. When the OD is switched off car run great, when I switch on the OD it will work fine as long as I don't put a load of any kind on it (ie; uphill, accelerate etc). If I try and speed up even the slightest, or come to a slight incline in the road the tranny begins to shift in and out of OD.
Sensor?
Ski_down_it - could this be a glitch in the chip you burned for me?
I'm fairly certain the tranny is not bad, it works to good except for these instances. Oil level is full.
Any ideas?
Rob
PS sorry for double post!! the 1st one didn't show up on my screen after I hit submit right away.
Reason: double post
