96 headlight question
Old Oct 6, 2007 | 09:39 PM
96_vette's Avatar
96_vette
Default 96 headlight question
My left headlight keeps making noise when ever I turn off the headlights. I think its the gear inside, I will open the inspection cover and look inside. Anyone performed this maintenance task? Is it a pain to replace?
Old Oct 6, 2007 | 11:55 PM
96_vette's Avatar
96_vette
I found this awsome link for replacement..... will do tommorow....
http://content.madirect.com/pdf/601701article.pdf
Old Oct 7, 2007 | 12:27 AM
MrRenoman's Avatar
MrRenoman
Here's another...
http://mywebpages.comcast.net/zrjuan/headlight.html
Art
Old Oct 7, 2007 | 08:55 AM
Louis Bartay's Avatar
Louis Bartay
Ecklers has the Bushing drive pins. I did this on my 96 and purchased a new delrin gear and drive bushings as trying to remove the the factory gear is hard to do with out hurting the teeth. Also file the new gear per the instructions that come with the parts from Ecklers. I removed the head light from the hood and did the repair on the bench. Took about two hours. The instructions from Ecklers were right on that came with the gear and bushings.
To 96 headlight question
