part number
Old Oct 7, 2007 | 11:52 PM
davidf4925's Avatar
davidf4925
Default part number
anyone know the part number of the temp sensor that is on the water pump of an 95 lt1.
Old Oct 8, 2007 | 12:13 AM
kylebuck89's Avatar
kylebuck89
St. Jude Donor '09
not sure.. but advance auto parts should have it in stock..
i just gota ask.. did u snap it off the water pump when u were messing with the belt? because thats what happend to the one i had
Old Oct 8, 2007 | 12:14 AM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Just happened to have my circa 2002 parts cd installed, so here it is:
Sensor, eng cool temp (und plenum) (used for clusters w/oil gage & LGT comb)(2 way M) -- ac/delco 213-310, GM # 12146312.
Although the definition seems odd, based on picture it is it...
It should be the sensor which drives the digital dash temp and the ECM.
Last edited by theadmiral94; Oct 8, 2007 at 12:17 AM. Reason: deleted comment about locktite
Old Oct 8, 2007 | 09:22 AM
davidf4925's Avatar
davidf4925
Default thanks
thanks for the part number, I'll check it out today. what happened was when I got the old water pump out of the car, it sliped out of my hand and broke the plastic peice that holds the connector on. thanks
To part number
