Calling Scorp
Old Nov 13, 2001 | 11:02 PM
84Coyote's Avatar
84Coyote
Default Calling Scorp
Hey Scorp,
I was wondering what your setup is currently to run a 13.8. My last run with my 84 was a 14.6. I just installed a chip and I can't wait to hit the track. :)
Old Nov 14, 2001 | 01:11 AM
scorp508's Avatar
scorp508
Default Re: Calling Scorp (84Coyote)
Hey Scorp,
Umm well.... my engine the L98 is different than your L83 in the '84 (Unless you have swapped it out, then I apologize.)
L83 = 205hp / 300 ft/lb
L98 = 240hp / 340 ft/lb (245hp in my case, different mufflers came on Z51 cars)
That aside.... :) the 13.8 run was down with (lemme think here).....
Hypertech Stage II Chip (Worthless)
Air Filter & Lid Removed
Short Shifter on my 4+3 tranny
Flowmaster Mufflers (Same flow #s as the stock ones though, just sound better)
Timing at -4 ( :eek: )
Bald Tires :)
TPS @ 0.68v/idle, which makes no difference since I'm at WOT the whole run.
Those are the only things that were done to the car at the time. So pretty much the only thing that might of helped was removal of the air filter, and the short shifter allowing me to be on the gas more, and shifting less.
Since then it has run anywhere (this is assuming a good run/shifts/launch which isn't always the case) from 13.8x to 14.2x times depending on weather/track conditions.
Old Nov 14, 2001 | 01:04 PM
FlyboyZR1's Avatar
FlyboyZR1
Default Re: Calling Scorp (scorp508)
Different mufflers on Z51 cars? I haven't heard that before. My '86 is Z51 and stock HP I believe (cast iron heads) is 230. Since I've got a Z51 you think I actually have more than 230?
:seeya
Old Nov 14, 2001 | 01:12 PM
scorp508's Avatar
scorp508
Default Re: Calling Scorp (FlyboyZR1)
Yes, sir. Lots of early C4s you will notice have 4 exhaust outlets, but only two of them are functional. The non functional ones are literally just welded onto the mufflers for looks. The Z51 cars (possibly Z52 also, although I am not sure) have all four outlets functioning and are more free flowing.
*edit*
As for your 86, I am not positive if the different mufflers were used at that time. I'll get back to you later.
[Modified by scorp508, 12:13 PM 11/14/2001]
Old Nov 14, 2001 | 02:02 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
Note: my stock 88 auto base coupe always runs quicker than Scorp's car at any given race.:) Muahahahahahaah
On the highway, they are dead even.
Old Nov 14, 2001 | 02:06 PM
scorp508's Avatar
scorp508
Default Re: Calling Scorp (Fastguy)
Shut yer' trap!!! :D I've trapped a higher MPH though. :yesnod: If we swapped cars, then it would probably be the other way around. I can't launch for crap.
Yer' just a' masta' drivin' pimp.... :jester
I'm going to E-Town this weekend, maybe I can redeem myself.
Old Nov 14, 2001 | 05:08 PM
Fastguy's Avatar
Fastguy
I ran a bunch of 101's at Lebanon Valley.
Biotch:)
[Modified by Fastguy, 11:13 AM 11/15/2001]
Old Nov 14, 2001 | 06:03 PM
scorp508's Avatar
scorp508
What?? I thought you said 100s, DAMNIT. :D
Old Nov 14, 2001 | 07:43 PM
L98Terror's Avatar
L98Terror
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
You guys are worse than old ladies :yesnod:
Old Nov 14, 2001 | 07:47 PM
scorp508's Avatar
scorp508
Default Re: Calling Scorp (L98Terror)
Behave yourself mr. ricer flyby! ;)
Old Nov 14, 2001 | 08:07 PM
korvetkeith's Avatar
korvetkeith
Check the times in my sig, I need to work the '60 ft. down to a 2 flat and I could pull a 14.3. The only mod is straight exhaust after the stock manifolds and the time was with the ZF6. The engine has some sort of rebuild on it, nothing special I don't think, no lump at idle, just tons of torque :cool:
Old Nov 15, 2001 | 12:15 PM
Fastguy's Avatar
Fastguy
Default Re: Calling Scorp (korvetkeith)
Keith, are you still running a crossfire motor or a TPI?
Old Nov 18, 2001 | 03:02 AM
korvetkeith
All times are on the stock crossfire injected. I have a new X-ram, and 1 5/8" full length LPE headers ready to go on, I still need the rest of the exhaust and some roller rockers that fit under the stock vavle covers. Hopefully I'll have a
"stock" crossfire that runs 13s :D
Old Nov 19, 2001 | 07:53 PM
84Coyote's Avatar
84Coyote
My 14.6 time et was only 93 MPH. Is it possible for me to be going 3 miles per hour slower and only be .1 slower than that time?
To Calling Scorp
