Anyone using this Catco Ypipe-Cat combo
link
Is it louder, better flowing?
thanks
It appears to come with the Y pipe. It is comes up under their ypipe link. The cat looks like the one that you get for $139 on its own, so the Y pipe component is a bargain (assuming it is not waffle bent).
Also Converter Overall Length (in): 64.500 in.
you will notice its slightly louder
i replaced the oxy sensor at the same time and i feel its a good pipe and cat so far, its been on my car for about 1k miles or less
the y pipe is not mandrel bent and seems to have the same bends as stock
you can sell your used cat to a scrap yard for at least 50.00 and they will take your old y pipe as well. its like a rebate
not much to the install but i had to cut the air pipe to the cat to size.
R U saying its waffle bent and not mandrel as it appears to show in the add at Summit which is now up to $216? Do you still have it on the car? If so how has it performed?
Thx!
