valve cover bolts
Old Oct 10, 2007 | 10:17 AM
KeyWestJack's Avatar
KeyWestJack
Default valve cover bolts
Does anyone know the size of the valve cover bolts on a 90-91 L98? I want to get rid of the torx head.
Old Oct 10, 2007 | 11:51 AM
Steel Blue 91's Avatar
Steel Blue 91
You might want to page Centralcoaster or he might chime in. He put together a kit some years ago that included valve cover bolts so he would know the size.
Old Oct 10, 2007 | 12:45 PM
KeyWestJack
I can not think of a better source of info. Thanks, Jack
Old Oct 10, 2007 | 01:07 PM
Aardwolf's Avatar
Aardwolf
I do not have one removed to check but I can give you two ideas. One is to take the bolt with you to the store. All the places that sell bolts that I have been to have a plastic gauge with nuts in it. You can test the size of the bolt in the metric or standard gauge. Also my micrometer has a thread gauge on the back, you can measure the bolt then check.
Old Oct 10, 2007 | 02:20 PM
KeyWestJack
I was going to order some from www.mcmastercarr.com (kind of my own custom set) and left my measurement at home (getting old). I then went to www.summitracing.com and ordered as set of ARP.
Old Oct 10, 2007 | 02:45 PM
SunCr's Avatar
SunCr
Street & Performance - www.hotrodlane.cc - carries some alternatives. You'll need to poke around their catalog or maybe call them.
Old Oct 21, 2007 | 03:24 PM
black88z51's Avatar
black88z51
If these are the same as the 88's w/ center valve cover bolts then I've got your bolts. Stainless Allen Key Head machine bolts. I just bought a **** load, enough to do 5 TPI engines. Contact me if interested. These are the bolts show cars use.
To valve cover bolts
