Is my FUEL pump enough???
Old Oct 10, 2007 | 08:21 PM
vette850's Avatar
vette850
Default Is my FUEL pump enough???
I have an '84 coupe with a modified 350 TPI that is pushing around 400 HP. I was in a bind the other day and had to put in a stock replacement fuel pump. My question is....how much should my pump flow for that kind of horsepower. Also it has 30 lb injectors installed, are they enough or do I have to go bigger?
Old Oct 10, 2007 | 08:40 PM
John A. Marker's Avatar
John A. Marker
The stock fuel pump is good up to "about" 400 HP. You are on the edge. As long as you are not racing or hitting WOT you will be okay. I would look toward replacing it with a better unit.
Old Oct 10, 2007 | 08:46 PM
vette850's Avatar
vette850
How much does the stock pump flow?? Can you recommend a good replacement?
Old Oct 10, 2007 | 08:54 PM
CFI-EFI's Avatar
CFI-EFI
The stock '84 fuel pump is designed to meet the spec for 9 to 13 psi fuel pressure. It does a good job and will exceed all stock needs, but I can't imagine it will provide the 40+ psi pressure the TPI needs for very long, if ever. To know for sure, test it.
RACE ON!!!
Old Oct 10, 2007 | 09:11 PM
vette850's Avatar
vette850
Default TRE performance 255 lph pump???????
I was just looking at a 255 lph fuel pump on ebay...costs $70. Has anyone tried one out....are they any good?
To Is my FUEL pump enough???
