# 8 plug
Old Oct 11, 2007 | 01:11 PM
the blur's Avatar
the blur
Default # 8 plug
any hints on removing that #8 plug ??
LT4 motor.
It's looks like I may remove the wire loom holder, or slice and dice my hands. Havn't decided which one is easier
Old Oct 11, 2007 | 02:35 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
On my L98 I have the two AIR tubes removed along with the A/C compressor rear brace.
Then I slide the socket over the spark plug and use a 5/8" open-end wrench on the end of the socket.
Old Oct 11, 2007 | 02:37 PM
JAKE's Avatar
JAKE
Had the same concern a while back - 96 LT1 -. I wasn't changing the plug, only the plug wires.
I ended up getting to it by standing on the driver's side of the car, hoisting myself up and laying on the top of the engine. That allowed me to reach old #8.
I'm sure others have different ways to access it.
Hope this helps.
Jake
Old Oct 11, 2007 | 03:12 PM
runner140*'s Avatar
runner140*
On my 96', I went thru the inner fender well. It took an hour to get #8 out and put replacement in. Think I still have cuts on both hands. I used a two inch legnth of heater hose to rethread the new plug. Good luck.
Old Oct 11, 2007 | 03:15 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
I put the socket over the plug, then used a wrench on the hex part instead of a rachet.
To # 8 plug
