I'm assuming I'm not supposed to have ANY play in my rear wheels, right? I just noticed an intermittent noise this evening coming from the right rear of my car. I jacked it up and was able to wiggle the R-R wheel a little bit. I checked the L-R and it had movement, but not as much as the R-R. So I'm assuming I need new hubs. (?) I've found prices from $80.00 to $160.00 and all are advertised as new U.S. made.
So #1. Do I need new hubs, as I suspect?
#2. Any reason not to buy the cheapest U.S. made hubs and save some $$$? If not, any brand I want to avoid?
I'm an impatient one. I had read everything I could find using the search function and had already figured the worst. After reading 50 pages of postings I ordered the "HP" hubs from a non-supporting vendor that supposedly have the tapered bearings. We'll see if the $296.87/Pr. delivered price is worth it soon enough. Luckily my tool collection already has the T-55 and 36mm sockets so I'm good there. Has anyone had any luck removing the center nut with an impact wrench, or am I destined to use the breaker-bar method?
One more question: I saw references in the threads I searched to a shim, but not much detail on it. Is that something I will encounter between the hub and the splined shaft?
My 36mm nuts came off easily with an impact wrench. I had my wife apply the brakes while i took the nut off to keep the wheels from spinning. Make sure you have a good quality (ie: no made in China junk) T55 torx bit.
Okay... here's another dose of reality: I had a little play in my rear wheel hubs, so I replaced them with USA made units. Even the new ones had a tiny bit of play in them. I'll worry about it if one of the wheels falls off.....
Are you sure the hubs are shot? The U-joints could be bad as well. You should check them out.
I have one AC Delco bearing and one bearing from Napa and have had no problems.
Yeah. Definitely play in the hubs themselves. I figure that once I get the hubs out I'll check out the U-joints and replace them too if they show any play. The car has 101k miles on it. I drive it pretty gently, but the more I read, the more I see these rear hubs aren't built to last that long.
Just a word of caution. The shake test takes up play in the suspension. The shop manual wants the wheel off and a dial indicator to check end play in the bearing.
If I remember it should be less than .006 in Mine were almost .02 inch out back and I couldn't figure out why the car was all over the road on ruttted up pavement.
I got bearings from Pep Boys years ago and they have held up under street driving. From what I read only a few companies make the bearings and everyone else just reboxes them including GM.
If you are going to the trouble to change the wheel bearings take the cap off a u-joint and take a look. For the time and effort I would change the j-joints while I had it apart; especially if I didn't know the history of the u-joints.
I recently put the $80 WBI bearing on mine and it is working well so far. No play! I broke the spindle nut loose before jacking up the car. No trouble with a breaker bar, this is a simple job but it can take awhile without a lift. Kind of hard to see the torx bolts.
Hoooo Leeeee CRAAAAAAPPPP! So when I first posted this I had parked the car after hearing a slight clicking for the first time EVER. I bought new hubs, but have been waiting for the new Teflon coated washers from my local Chev. dealer and haven't driven the car since. So this evening I decide to take it out and am only on a leisurely cruise. About a mile from the house the R-R starts making a GRINDING noise every time power is applied at any level other than traffic-impeding rates. Not only could I HEAR it, but I could FEEL it! Boy was THAT quick; Drove fine... Made slight noise on one drive... Grinding parts on the next! I'm parked now 'til the washers come in.
Well I was right. And I was wrong. I finally hit the garage yesterday to R&R the hubs. I figured that with 100k miles on it, I'd be well served to go ahead and replace the 4 U-joints as long as I was taking things apart.
Good thing. Of the four U-joints, one was in a condition that I'd describe as "okay." Two had at least one bearing that was gritty. And the R-outer had one bearing that was completely destroyed. That was my grinding noise.
Once I got everything apart the hubs really didn't feel bad at all. They both turned smoothly and the resistance felt right, but I noticed that they both had their inner seals going. Once I got the new hubs on and all reassembled I did the wiggle test again. There is now NO play in the hubs. So even though the old ones had noticeable play and were obviously in need of replacement, there was no bearing grinding or danger in them.
So there's my short story. From now on as long as I own a C4 and I drive as easy as I do, I will still consider all 6 U-joints as a 50-k mile service item and the rear hubs as probably a 100k service item.
These discuss the intricacies your dealing with......not so much the u-joint issue but the rest of it.
These multipage threads on the subject may be why not many posted replies in your thread....
Yes. I have followed both of those threads, among others. I'm glad that I discovered the info on the Teflon-coated washer, as I ordered and replaced both of those also. My originals were really screwed up. Sadly, I ordered my tapered-bearing hubs right before the group-buy was organized.
What I am interested in was the U-joint issue. I need two half shaft u-joints at this time.
Easy to replace. Both ends are held in place by U-joint caps. You will need to pull the lower locating arm from the hub to move it far enough from the center to have enough room to drop the half-shafts out. I didn't pull the upper locating arms, the ones that adjust toe, but in retrospect, I should have. It was a MAJOR PITA to move the hubs enough to drop the shafts. Had I removed those upper locating arms it would have been a LOT easier.
I used my hydraulic press to replace the first U-joint. After it went in very easily I used a plastic hammer the replace the other three.
