90 L98 - Stalling, running rough when cold/damp
So far I have checked:
Plugs and wires: All wires show very low resistance and no opens when twisting. Plugs are about 10k old NGK V-Power. Wires are about the same age.
Injectors: All injectors are at 12.4ohm cold. They are LS1 take-offs (from SLP) and have about 20k on them.
Fuel pressure: 44psi engine off, key on. 35psi idle and smoothly follows the throttle. The pressure did not drop off when the car tried to stall.
Vacuum: Very steady 19-20inHG at idle.
Distributer: Cap/rotor/coil all have about 20k on them. I've looked at the cap and it does not appear to be too crudded up inside but I am not sure what kind of real diagnostic test I can do.
I have access to DataMaster if anyone thinks that some datalogs might be helpful. I'm kinda lost. Any suggestions?
Thanks!
after replacing the MAF the problem went away. take the MAF off and look to see if the filament is still intact, should look like a light bulb filament. If your car dosent have a MAF then maybe you need one.
Could even be just the MAF relays
I pulled out all the plugs and didn't see anything unusual. They all look clean - no buildup on the electrodes. The gap was still at 0.035. None of them were loose or messed up as far as I could tell.
A ran a log while moving the car in the driveway. I can't see anything amiss. The CTS and IAT seem normal. The hesitation can be seen when I blipped the throttle - there is a significant delay before the engine revs up. It wasn't very cold/damp when I ran this so there may not be enough to go on. The log is a CSV exported from Datamaster. If you need some other values shown, I can re-export it.
Log
Any more ideas?
The log I see doesn't show me enough info, and appears to be a snap shot of running from 70-80mph? If you have a datamaster log, with idle etc. at warm-up and in closed loop may help.
The last column in that log is speed... 0-5mph or so.
Datamaster log in the driveway: Here This log shows me moving back and forth in the driveway. The car almost stalled a few times but it recovered.
Datamaster log running around the neighborhood: Here The end of this one shows the engine jerking and changing speed with no change in TPS. This has some open and closed loop data.
I may be able to get a better log during the stalling/hesitating episodes in the morning if it would be helpful - I won't like getting up extra early tho
. I have a feeling the logs will be inconclusive. This seems to be a "mechanical" problem to me - something is crapping out that has nothing to do w/ the ECM directly. I could be wrong.Thanks for the help!
At certain places of idle I see the timing dropping as low as 8* (near end of log when at 195 OT), should be at approx. 20*(closed throttle setting in chip). This could keep the BLM rich off idle, as I am seeing in your logs (OT)
My experience on MAP cars, is when the fueling changes as dramatic as what I see in your logs, it usually causes it to have a strange reaction/s. Going from a low BLM of 108 ish at 800 and then climbing into to power band (starting at 1k rpm -3K+ from 50-80ish kpa.)it goes way lean (150+), way fast. (feeling like a miss, stuttering etc. when that much fuel is being removed). As your OT increases, at idle your BLM is dropping and is out of range (109) for the ecm to comp.
The rich idle should be addressed, as well as adding fuel in the 1100 -4000rpm in the 50-80 kpa areas, spark knock and pulling timing approx. 4* should be addressed as well (adding fuel would probably fix that area). The de-cell through 30-25 kpa is going a bit lean as well.
Because I have never seen a "before" log, and if we are to assume it was right to begin with, there may be a fueling problem which would be a reason for it going so lean under load. ???
Is this a stock tune ?
This problem did not appear until later, tho. I think I have a copy of the original bin on an old laptop. I can put it back on and give this another try.
I find it odd that the tune would have fixed this even tho the problem only appeared a short time ago - long after the changes were made.
New DM log: Here.
If I am reading this right, the BLM is still 108 most of the time. I suppose I should really take some time to tune this thing. Odd that the stock tune would be so far off.
Thanks for the help! Hopefully it is really fixed.
I noticed yesterday that the idle still acts funny. When coasting at speed with either the clutch engaged or in neutral the idle likes to "bounce" - it'll jump about 3-400rpm then drop back and repeat. As soon as the speed gets less than about 7-10mph, it returns to a normal, steady 750rpm.
If I am reading this right, the BLM is still 108 most of the time. I suppose I should really take some time to tune this thing. Odd that the stock tune would be so far off..
As I have added various little changes after the initial build, I have had to tweak ve tables, PW decay, IAC cts. in drive, dead band, closed throttle pos.timing, AE, values, etc. etc. etc.
As to the neutral at MPH, this can tweaked in a number of ways. Slope gain, iac follower decay, pulse width decay etc. and would really depend on what you are seeing on the scans at the time of the event.
Before doing any of the aforementioned it is best to begin w/blm's being under controll, and all other tweaks when motor is at OT, then work backwords for cold settings.
The idle is steady with no apparent miss and all the plugs look great so I would guess the ignition system is running fine. Under load the engine is reasonably smooth now that I have the stock tune back. I can use 6th gear at 50mph again w/o the engine bogging (much).
