1996 LT4 engine question
Old Oct 13, 2007 | 03:05 PM
bradf_nc's Avatar
bradf_nc
Default 1996 LT4 engine question
I sold my 94 LT1 car and now I am looking at a 96 LT4 car. Does the LT4 engine have the same crappy optispark set up as the LT1?
Regards,Gary
Old Oct 13, 2007 | 03:11 PM
Mojave's Avatar
Mojave
Regards,Gary
Yes, LT4's have the same optispark as an LT1. Chevy changed the design in 95 from the early models. The 95+ have a vent line, as well as a pin to drive the opti off of the cam instead of the splines of the early models.
redrose's Avatar
redrose
96 has a different opti drive and has forced ventilation...otherwise same pita as 94
Old Oct 13, 2007 | 03:24 PM
bradf_nc's Avatar
bradf_nc
Doust! Thanks for the information gang. I can pretty much cross C4s off my Christmas wish list and start looking at C6s now.
Regards,Gary
Old Oct 13, 2007 | 03:49 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Regards,Gary
Glad you gave up on the LT4 so easy!
There are thousands of them out there, that have never had any issues with the OptiSpark.
Old Oct 13, 2007 | 04:42 PM
StealthLT4's Avatar
StealthLT4
the opti on the 95 and 96 models is much more reliable than the <94's. You really shouldn't rule them out simply on that account.
Old Oct 13, 2007 | 05:09 PM
redrose's Avatar
redrose
c4 electronics are poor -- until you compare to the probs the c5/6 cars have...rotsa luck, don't say ''nobody told me''.
Old Oct 13, 2007 | 07:17 PM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Default Lt4
I am glad GM did improve the opti-spark. My original owner 96 LT4 has about 38K highway miles on it with no problems yet with the opti-spark. Don't know how much mileage one can get from the improved system.
Old Oct 13, 2007 | 07:29 PM
Mojave's Avatar
Mojave
I did an LTCC coil conversion on my LT4. It uses the optical half of the opti-spark, but gets rid of the cap and rotor (the part that gave me all my problems).
Old Oct 13, 2007 | 07:47 PM
LouisvilleLT4's Avatar
LouisvilleLT4
Great, more LT4's for everyone else. The presence of the Optispark is a terrible reason to not get one. The Opti is a great engineering feat if you just take care of it and don't wash your engine and make sure your water pump is sealed properly to the engine. I can think of much better reasons not to get a C4, namely the fact that the C5's have 40% more torsional stiffness and 40% fewer parts. And the C6 gets it even better. If cost is not an object, get a C6 instead.
Old Oct 14, 2007 | 02:24 PM
Irishpilot03's Avatar
Irishpilot03
I know there are horror stories about the opti, but I've done lots of mods, drive the car hard, never wash the engine, and I've got 50,000 miles on the original opti. I agree with the above posts, there are other reasons to look at newer vehicles, but the opti shouln't be a make-or-break reason to not get an LT4 car.
Old Oct 14, 2007 | 02:38 PM
etteroc27's Avatar
etteroc27
The opti on my 95 was working fine at 83,000 miles. I replaced it when I had to replace my leaking water pump just because I was in there. The water pump had leaked on it for two weeks before I replaced it, and it still worked fine. I have 5500 miles on the new GM opti, and no problems. I would buy another lt1 or lt4 in a second. Not a good reason to rule out one of the best looking corvettes ever made.
By the way, I work for a sheriff's office, and in the mid 90's we used caprice police package cars. We probably had 50 or 60 of them, and I assume they had opti's on them. They came off the line at 125,000 miles, and there were no problems with them either.
Old Oct 14, 2007 | 03:32 PM
bogus's Avatar
bogus
Truer words have never been spoken.
The C5/C6 are fine cars... but don't go beating on them... the entire transaxle has proven to be not all that stout.
The LS7 is having valve train issues...
From my observations, I have heard of more C5/C6 transaxle failures than I can count. The ZF6/D44 has proven to be seriously strong. And the LT4 is dead nuts reliable.
So... trade off a potential optispark issue for a potential drive line failure... hm...
Old Oct 14, 2007 | 04:23 PM
Rimcrew's Avatar
Rimcrew
What's the big deal anyway? If the Opti does go bad, they can be had for around $250, and it takes about half a day to replace and is not that hard.
I was concerned with them too, but once I learned about them - I have zero concerns. All mechanical parts can fail, but I don't see the Opti as being more unreliable than any other piece of equipment.
Maybe I am to new/naive to realize the dangers...
Old Oct 14, 2007 | 09:02 PM
larryfs's Avatar
larryfs
I own 2 96 chevy's. Never had an opti problem. I keep reading about them, but that's about it.
Old Oct 14, 2007 | 09:14 PM
Trebor's Avatar
Trebor
My '96 CE LT4 Z51 with just 14,000 miles on it was spewing what I thought was steering pump fluid all over the underneath of my hood and onto the front cross member. I screwed around with it by sticking in Lucas leak stop to see if it made any difference. Nope , just got worse. I finally took it to the dealership where they told me that the water pump was peeing all over the place (result of a low mileage non-driven car said Mr Mechanic). The mechanic said had it been an earlier model the opti would have been toast. But because of the improved design , viola. Good to go and no damage. Testament to improved GM Engineering
Trebor
Old Oct 14, 2007 | 09:30 PM
lt4obsesses's Avatar
lt4obsesses
Regards,Gary
If you can seriously afford a c6 and know anything about them, I don't know why you would even consider a c4 LT4. However, if Santa doesn't come through, the LT4 is your best option. Mine has 50k and is a daily driver. When I bought it, it was somebody's garage queen. Thus the inner seal in the water pump dried out. The opti stayed strong. I have put 25k in the last year and never, I repeat never, even the slightest misfire. For the money, you couldn't buy a better performer.
btw, the lt4 is ridiculously more powerful than the lt1. the 30hp difference must have been a typo!
To 1996 LT4 engine question
Old Oct 15, 2007 | 11:38 AM
NEVRL8T's Avatar
NEVRL8T
Either that or your just obsessed with the LT4 and a little biased.
Old Oct 15, 2007 | 11:41 AM
StealthLT4's Avatar
StealthLT4
the LT4 was underrated by GM for insurance purposes. I don't know what the exact numbers are, but maybe 345hp/350ftlbs instead of 330/340. At the crank tho.
Old Oct 15, 2007 | 11:52 AM
TorchRedlt4man's Avatar
TorchRedlt4man
From: Chicago Executive Airport, formerly known as Palwaukee
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
I have over 94,000 miles on my original LT4 optispark. The water pump was replaced under an extended warranty at about 50,000 miles. I put on an Accel distributor cap & rotor at 90,000 miles. The opti was in perfect condition, except for the rotor screws that had backed out and were sitting in the bottom of the distributor. The engine was still running strong but had a little erratic idle. The design prevents the rotor from coming completely off. There was side-to-side play which accounted for the idle.
I have washed my engine too many times to count! The '96 OEM opti is sealed very well. The Accel cap & rotor comes with two (2) silicone o-ring gaskets that are pretty trick and seal up the unit perfectly.
What everyone is saying about the driveline is no joke. The D44 and the ZF are bulletproof. I also have the dreaded original dual-mass flywheel and clutch assembly in mine!
