removing the 9th injector
Old Oct 13, 2007 | 09:48 PM
scootert96's Avatar
scootert96
Default removing the 9th injector
ok im kinda new to c4s and i have a 86 with iron heads im planing on upgradeing to the l98 alum heads and i have found an intake that i like but it dont have the 9th injector can i take the 9th injector off and have no problems with the engine also can i take off the egr and still have any problems??? well thanks and hope someone can help me
Old Oct 13, 2007 | 10:06 PM
_twisted_'s Avatar
_twisted_
You will experience hard cold starting, you can get a chip done from PCMforless and they will program it accordingly for the CSI delete, EGR delete and other changes like the fan temp etc.
Old Oct 13, 2007 | 10:21 PM
scootert96's Avatar
scootert96
Default thanks
would you happen to hve the number or web address
Old Oct 13, 2007 | 10:46 PM
_twisted_'s Avatar
_twisted_
pcmforless.com Alvin will do the chip for the 86
Old Oct 13, 2007 | 11:13 PM
redrose's Avatar
redrose
best for longevity of your engine to ''crank for oil pressure'' prior to light-off (s.o.p. for racing engines)... some truth to the tv adds that say most of wear occurs at start-up ( but due to oil drain-down from internals, not lack of their additive),... however, extended cranking is not desirable, esp if ''flat tappets'' are used (roller tappets are more forgiving), thus in ambient temps under abt +40*F the CSI is helpful.
ran my L98 many years with CSI unplugged, current lt1 intake conversion has no provision for ''ninth injector...no prob.
Old Oct 14, 2007 | 12:43 AM
scootert96's Avatar
scootert96
Default 9th
did you do anything to the pcm for your corvette
Old Oct 14, 2007 | 04:27 AM
rodj's Avatar
rodj
Best way, get all the good mods in one go or you can get a chip from a '89 ( no cold start injector ) that has the fuel enrichment at start up to compensate for no cold start injector
Old Oct 14, 2007 | 08:58 PM
redrose's Avatar
redrose
nothing done to the ecm...tape the CSI connector to reduce corrosion in case your every decide to resto...note that if used, the CSI only operates for eight seconds before it ''times out'' and shuts off anyway.
To removing the 9th injector
