head and cam?
Old Oct 13, 2007 | 10:48 PM
Kool88vette's Avatar
Kool88vette
Default head and cam?
I'm planning to install a Lingenfelter 219 cam. I have a Super Ram, ZZ4 heads with Comp Pro Magnum 1.6 RRs. Is it a good idea to run the 1.6 RRs with the 219? Will the springs be OK? I'm planning to change injectors at the same time. I have the old yellow 24 lb. Acell injectors. Should I stay with 24 lbs? I'm also looking for an Accel base. It has the stock base now. Any suggestions? I would like to make this the last tear down.
Old Oct 13, 2007 | 11:37 PM
aklim's Avatar
aklim
Sure. I believe that is what it was designed for.
Dunno. Have them checked for .560 lift.
Talk to the chip programmer
Old Oct 14, 2007 | 12:12 AM
STL94LT1's Avatar
STL94LT1
I'm pretty sure the ZZ4 heads have LT4 valve springs. If that is true, you will need to change springs.
Old Oct 14, 2007 | 04:27 AM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
LPE makes springs for the cam. http://www.lingenfelter.com/store/ln0018dblas.html
Old Oct 14, 2007 | 01:07 PM
Kool88vette
I think the ZZ4 springs are good for .550 lift. Won't the 219 cam with 1.6 RRs give me .590 lift? Will it be too much for the springs. Maybe I need a less aggressive cam.
Old Oct 14, 2007 | 01:26 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
I would go with the 219 and change the springs. Normally you wouldn't match cam to springs, you would match springs to cam.
Old Oct 14, 2007 | 02:25 PM
vader86's Avatar
vader86
No dont change the cam choice, change the springs.
As for injector size, talk to the tuner first.
Old Oct 14, 2007 | 04:37 PM
Kool88vette
OK I'll do some more research, thanks
Old Oct 14, 2007 | 04:54 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
The 219 will give you .562 with 1.6 RRs BTW, I got mine in this weekend. Don't forget the assembly lube...
Old Oct 14, 2007 | 07:00 PM
Kool88vette
I don't mind changing the springs. It's not a big expense. I just thought that I might have too much lift and the car might not be streetable. I plan to bring it to shop here that will do the work and a dyno tune. I don't feel comfortable changing a cam. Never did one before. That's why I want to get everything right the first time.
Old Oct 15, 2007 | 12:31 PM
STL94LT1's Avatar
STL94LT1
If the heads will support it, go with the lift. Lift is free horsepower, will have very little to do with being streetable. My camshaft has 605/622 lift, and drives near stock-like.
Old Oct 15, 2007 | 12:39 PM
Red Tornado's Avatar
Red Tornado
.560 lift isn't anything crazy at all.
higher lift only means you'll likely need to change the springs more often. with a 219 cam, if you're not at the track every day you'll probably go 40-50,000 mi. between changeouts.
Old Oct 15, 2007 | 12:49 PM
aklim's Avatar
aklim
It was enough to wipe out the HD springs that Trick Flow recommended on their heads which caused a valve to float and a piston to hit it.
I suggest you do it right the first time and get the LPE springs. They know.
Old Oct 15, 2007 | 01:12 PM
Kool88vette
I'll get the Lingenfelter springs. They're only $68.95. Why take a chance.
Old Oct 15, 2007 | 01:26 PM
aklim's Avatar
aklim
For $70, you'd be an idiot to take the chance. Here they are with something they know will work. Didn't they give a 2 yr 24K warranty on their motors? They know you will beat the **** out of it too. A normal 3 yr 36K warranty on your car is safer than a 2 yr 24K warranty on an LPE motor. Nobody I know of buys such a motor and putz it around town.
Old Oct 15, 2007 | 01:41 PM
Red Tornado
what i meant to say is that once the (correct) springs are installed, a higher lift cam like the 219 will mean more maintenance in that the (correct) springs will need changed out about every 40-50,000 miles....which is no big deal.
Old Oct 15, 2007 | 01:47 PM
aklim's Avatar
aklim
Oh, I see. Well, FYI, my TFS HD spring kit went about 30K before I discovered the break of one of the springs.. On the right side, every valve was loose also. Great QC.
Yes, about 40-50K is a good time to change springs. By then you would have gotten bored with the car and switched springs to accommodate a BIGGER cam.
Old Oct 15, 2007 | 01:53 PM
Kool88vette
6 months ago I swore I would never change the cam. Too much money. The need to speed is greater than my urge to conserve. Hope I don't go broke.
To head and cam?
